Anyone get there ISF's oil changed or tires rotated at the dealership yet?
Since some of you have had your ISF for a while now, I was wondering if anybody has taking there car into the dealer to have the oil changed and the tires rotated? If so what seems to the going rate for each of these items?
one thing to note abt tire rotation that i realize today is:
the IS-F rims r directional, so if u swap them left and right, the rims becomes backwards, but it's not very noticeable... BUT i have also heard rumors that the IS-F rims are designed to extract heat from the brakes, IF this is true, then it's not that good of an idea to swap the rims left and right, BUT if this rumor is false, then i would rotate the tires to prolong it's life with the exception that the rims will be spinning backwards, but it's very not noticeable...
Each tire and wheel is designed for its position on the vehicle. Therefore make sure they are fitted in the postion indicated on the reverse side of the wheel
Page 312 owners manual
It is designed to pull heat from the brakes. For example. If you put the left front wheel on the right front the spokes will be different
Sorry for making decision from pics, still waiting for mine isf to come.
P.S. it that case that they are directional, they do pull more air to brakes, to cool the better..
so when is the isf coming? you got a nice collection there
but yeah, the wheels are directional, it's in the spec to make sure people don't mix them up
on the other hand, the rotors are not directional left and right. i checked, indeed left and right are the same, the vaines inside are the same
if u're asking me, I am starting to get pist...
first, lexus planed to get their first IS-F's on like a month ago, but now, they only get info, that it won't be earlier then May end, but no concrete date.
It looks like story is going to repeat, when I was told, that LS600hL will come no earlier then a month, and same day, they called and said that after weekend it will be delivered.
I don't believe, that they don't have info of car arrival date. I believe that every procedures are counted, and dates known...
Hate lexus for this information unknowiness...
Officialy, u cannot still order IS-F here, but it is kind of ordered..
