Cross drilled brake rotors collecting dust
i believe the factory service manual recommends you clean out each hole with a q-tip or the like every 5k miles for best performance. besure not to use each end of the q-tip on more than one hole, you don't want to cross contaminate the dust.
comon!!! when car is washed with high presure water all holes get cleaned..
do you start taking out small stones from tires every 5k miles??!! it is just dust!
For all that are confused, I'm not complaining about the brake dust. I was talking about the holes getting filled up. I expect a high performance car like this to generate a decent amount of dust but I was unsure of the build up of it in the holes.
Tech Info Resource
If you'd like to think the discs will be less than a grip a piece, dream on. Low volume, low sales, high tech...no way they'll be cheap. Hopefully they'll be cheaper than the $300 a piece for WRX STi rotors, but with all those pretty holes, who knows...
None of the Lexus parts listing places have ISF individual pieces yet.
Bringing an old thread back to life. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
In preparation for a HPDE event next weekend at Summit Point, WV I was checking my brake pads today to see how much material I had left and noticed that my rotors were also very clogged. Not sure how much it would affect things, but I took no chance and used a drill bit and cleaned them all out. This is going to be my first HPDE event and going in with stock brakes I want to make sure they are in optimal condition. If all goes well and I end up doing more of these events I'll switch over to some Carbotech XP12's.
Clogged!
![](http://i123.photobucket.com/albums/o304/caymandiver75/Misc/IS-F/Front%20brake%20pad%20replacement/Rotors%20Clogged/photo2.jpg)
Cleaned out.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
![](http://i123.photobucket.com/albums/o304/caymandiver75/Misc/IS-F/Front%20brake%20pad%20replacement/Rotors%20Clogged/photo3.jpg)
Clogged!
Cleaned out.
![](http://i123.photobucket.com/albums/o304/caymandiver75/Misc/IS-F/Front%20brake%20pad%20replacement/Rotors%20Clogged/photo4.jpg)
