Wheels on IS-F
Old 06-05-08, 06:25 PM
uplusd
uplusd's Avatar
Default Wheels on IS-F
Will my current wheels fit an IS-F?
19x8.5 +38
19x10 +42
Old 06-05-08, 07:37 PM
cliffud
Former Vendor
cliffud's Avatar
just throw them on and see what happens.
*grabs popcorn to see what happens too*
lol
Old 06-06-08, 11:32 AM
uplusd
uplusd's Avatar
Does anyone know?
Old 06-06-08, 11:38 AM
passnu2
passnu2's Avatar
so long they clear the BBK you are fine!
I have 19x8.5 +33 front & 19x10 +38 rear on the IS350
Slap them on and post pics
Old 06-06-08, 12:12 PM
Faymester
Faymester's Avatar
i've heard that it's really hard to find rims that will clear the breaks well enough ... i'm pretty sure you don't want to have to replace the breaks
but i would try them, just make sure everything clears before you start driving around
Old 06-06-08, 01:08 PM
passnu2
passnu2's Avatar
actually the calipers are slightly smaller on the F then the IS350...If the rims are made for BBK clearance then you are just fine. Even if not you may have enough room.
Last option is put a 5mm HUB centric spacer and it will clear that BBK Actually I would put this to flush the rims with the fender IMO it will look much better!
Old 06-06-08, 01:09 PM
uplusd
uplusd's Avatar
The fronts are made for BBK clearance. I'm mainly wondering if they will look nice & flush on the car?
Old 06-06-08, 03:16 PM
passnu2
passnu2's Avatar
they will look good. 5mm spacers will put them right at the fender line and be flush I would install then first before you get the spacers to see if you like it for your taste. I would get 5mm if it was my car.
Old 06-06-08, 05:18 PM
SMT
SMT's Avatar
Default Wheel Spacer
Will the 5mm hub centric spacer do the same for the OEM IS-F wheels?
Old 06-06-08, 05:30 PM
uplusd
uplusd's Avatar
Are the fenders wider on the IS-F than on the 250/350?
Old 06-06-08, 11:55 PM
SoCalSC4
SoCalSC4's Avatar
It's not that the IS-F front calipers are smaller; they simply have less "X factor"
(overhang) than the OE IS350 calipers.
I'd be more concerned with the REAR wheels clearing the rear calipers...
Low-disk rear wheels will NOT clear.
350ISRYDER
06-02-23 03:15 PM
Hameed
IS F (2008-2014)
12-29-12 12:17 AM
fr0st
03-14-11 01:08 PM
djsai
Wheels and Tires Classifieds
02-28-11 12:53 PM
pez13oigt
04-19-10 10:28 AM
Quick Reply: Wheels on IS-F
