Real Drive Question
Is the IS-F independent suspension on all four or those it has a solid differential in the rear?
If you where to upgrade the suspension to soften but maintain the spert characteristics what brand of shocks would you go for?
This isnt a mustang of course it has an independent rear. There are no shocks out yet for the IS-F but some adjustables may be out soon once companies develop them.
Lexus Connoisseur
The IS-F rides on a double wishbone front and multi link rear.
Here are the specs on Lexus.com:
Suspension
Front
Double wishbone with high-mount upper arms, high-rate coil springs with bound stopper, monotube gas-filled shock absorbers, large-diameter hollow stabilizer bar
Rear
Multilink suspension, high-rate coil springs with bound stopper, monotube gas-filled shock absorbers, large-diameter stabilizer bar
http://www.lexus.com/isf/isf/specs.html
Suspension
Front
Rear
As above, the IS-F has a fully independent suspension on all four corners. If I understand correctly, it does not have a traditional limited slip differential (like the BMW M products) but rather uses it's computer aids to similar ends?
Lexus Connoisseur
E-LSD to keep traction to both wheels in all driving modes Normal, Sport and All Off.
Aha! No wonder I don't just leave 1 black tire mark like I used to with my IS350 with all off! I'm glad they left the ABS and E-LSD on during the all-off mode!
If a company develops one I will also be interested. Keep me in the loop. Thanks.
New Product RRRacing / Penske Suspension Development for ISF
RRRacing
CL Vendor Products for IS-F
63
11-03-15 05:03 AM
