Any Other Dyno's????
Old 08-12-08, 06:43 AM
houstonT
houstonT's Avatar
Tooth - yea, it would be great to have more dyno graphs to compare against... I think I may have a freak as my car was BONE BONE stock, both mine and John's have the Bridgestone tires...
caymandrive - no problem...as I posted, it must be a freak. The conditions on John's run were VERY similar to mine. Neither of us had fans on the front, both of our cars sat for a bit prior to dyno'ing them, both had 93 in the tank, etc...
Peter
Old 08-12-08, 06:59 AM
LexISguy
LexISguy's Avatar
So guys the ps2's dyno higher then the potenza's? On average the IS-F is about 350whp give or take 5 or so whp due to the conditions.
Old 08-12-08, 08:14 AM
caymandive
11 Second Club
caymandive's Avatar
It really shouldn't make much of a difference between the two tires. The PS2's are 26lbs vs 27lbs for the Potenzas. The amount of tread on the tire would be a larger factor I would think than the 1lb difference.
Old 08-19-08, 11:49 AM
caymandive
11 Second Club
caymandive's Avatar
Originally Posted by CrazyMPG
temperature matters a lot right when dynoing? You will see some dyno numbers from my car soon....doing some testing....
oh just wondering what gear did you guys dyno your car at? mine was at 6th gear on a dynojet but for some reason it made the chart look all squigly...the guy said it was because at 6th gear he was going to 170mph, but when he did a 5th gear run the chart looked alot smoother...I think we all know that the 6th gear is the correct ratio to dyno the car...but I wonder what other people did on their dynos...
How is your "testing" coming along?
Polkman
IS F (2008-2014)
32
08-09-13 11:40 AM
KC95SC400
Performance & Maintenance
26
11-22-08 08:39 PM
rsa supra
CL of Southern California
11-15-07 07:44 PM
rsa supra
06-09-07 01:36 PM
Quick Reply: Any Other Dyno's????
