Personalize Settings
Unfortunately, the seat belt warning is not one of the settings you can personalize. I changed my climate control to stay in the last position instead of resetting to recirculate. I also changed the setting to have all the windows open but not the sunroof when you stand outside the car and hold the unlock button on the remote.
Thanks to bring this up. The air operation is something that drives me crazy. First of all there should be ***** to control air, pushing buttons and a touch screen takes too much time and attention. The rental -an ugly dodge- I was driving the other day at least had got this right. On the F I seem to always set it one way (like fresh+no AC) and it then eventually changes to something else after a while or the AC turns itself on or off because it thinks I want AC if I set it to recirculate or the other way around. Very poor user interface.
Originally Posted by terenshi
1. turn the key to the ON position which means pressing the start button twice on the new IS since it doesn't has the key, foot off the brake
2. Press the trip reset button couple of times until the ODO is displayed (not trip A or B)
3. turn the ignition to the LOCK (OFF) position
4. unbuckle the driver's seatbelt if it was buckled.
5. turn the key to the ON position again press the start button twice. when the dash lights comes on, press and hold the trip reset button and count a slow 12 seconds. (editor's note, hold it more like 30 sec)
6. while still holding the trip reset button, buckle the driver's side seatbelt.
7.and the odometer display should read "b ON" or "b OFF". toggle the beep OFF with the trip reset.
8. the process should be completed when you unbuckle or turn the key off.
