IS-F TSIB thread...
I did a copy/paste from tech-info site under service bulletin section for a 08'F model. Only a few PDSs are specify for the isF... and nothing major.
If you need more detail, I think it is $10 day pass.
https://techinfo.toyota.com
08' ISF SB, 09/18/08
1. L-SB-0090-08: 03-08 Applicable Models: Upper/Lower Windshield Tick Noise
2. L-SB-0085-08: 00-09 Applicable Lexus: Engine Serial Number Location
3. L-SB-0084-08: 06-09 Applicable Lexus: Automatic Transmission Serial Number Location
4. L-SB-0083-08: 91-09 Applicable Models: Permanent-Type Protective Wax Coatings
5. PG008-07: All Lexus Models: Replacement Certification Labels (Obsolete)
6. L-PDSB-0126: 2008 - 2009 IS350/250/F PDS Manual
7. L-PDSB-0120: 2008-2009 IS350/250/F PDS Check Sheet
8. L-SB-0048-08: 90-09 Lexus: Replacement Certification Labels
9. L-SB-0036-08: 05-09 Applicable Lexus: Smart Key Battery Diagnostics
10. L-SB-0031-08: Applicable 06-08 GS, IS, & LS Models: A/C Filter Replacement
11. L-SB-0026-08: 90-09 Applicable Lexus: Alignment Pin Installation during Transmission/Transaxle Assembly Installation
12. L-SB-0021-08: 9309 Lexus: Cylinder Head Cover Baffle Precautions
13. L-SB-0015-08: Disconnect Battery & Perform Zero Point Calibration After Wheel Alignment Adjustment
14. Paint Stains Under Rapgard (TM)
15. BO002-08: 08 Lexus: Seat Belt Extender
16. PG001-06: Battery Maintenance for In-Stock Vehicles & Pre-Delivery: All Models & Model Years (Revised)
17. SS005-07: 90-08 Lexus (SRS-Equipped): SRS Component Disposal as Hazardous Material Treatment
18. SU001-08: All 08 Lexus: Repair Manual Supplement: Vehicle Pulling to One Side
19. PD082-07: 08 IS F: Initial Calibration of Compass During PDS
20. PD080-07: 08 IS F: Tire Pressure Warning Valve/Sensor Activation
21. PD078-07: 08 IS F: Front Wheel Opening Extension Pad Installation During PDS
22. PD077-07: 08 IS F: Front License Plate Mounting Bracket & License Plate Installation
23. PD074-07: 08 IS F: DCC Fuse Installation During PDS
24. PD073-07: 08 IS F: Initialization of Power Window During PDS
25. PG007-07: All Lexus Models: Replacement VIN Plates
