How about a national IS-F drag competition?
#121
11 Second Club
-3 lbs for engine cover - just the center one for better engine cooling
-36 lbs for spare/jack/tools
-6 lbs for trunk mat
-40 lbs for rims/tires
total for me 85 lbs but VERY low fuel load (0 miles to empty)
#122
Here is a run down on the weight reductions for me with the car having ZERO power mods. Just to note the 18" IS350 wheels that I use at the strip with drag tires weigh more than the OEM 19" IS'F rear wheels by about 1lb each and only used for consistent launches. Key word being consistent as they will not yield quicker ETs. Reason being the stall speed on the tranny is too low to give a powerful jump out of the hole so the best way to get quicker launches is by going with a lighter weight wheel/tire combo as tooth doc has and other weight reductions such as running low fluid levels (gas, windshield) and not being overweight helps too. ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
-7 lbs (engine covers)
-6 lbs (trunk mats)
-36 lbs (spare/jack/tools)
-26.5 lbs (lightweight battery kit)
TOTAL 75.5lbs
So not quite 100lbs but closer to 75lbs is easily achieved without stripping the car into a un-Lexus type ride.
-6 lbs (trunk mats)
TOTAL 75.5lbs
Also, I noticed you had better times in the 350 with ECT/Power mode disengaged, right? Not the case for the F, relating to Sport mode?
#123
Thx for the info guys BTW, Cayman, I'm proud to be in your journal for the 2is btw (even if I am the slowest at 13.2. Can you confirm again, the reason for just the .5 second difference in your best IS350 vs. IS-F times? Is it simply because you'd done more mods to the 350, and fewer to the IS-F, besides weight reduction?
As for the 350 with ECT/Pwr mode disengaged..it's true that you will get better times with running the car in standard mode not ECT/Pwr. The IS-F on the other hand must be used in manual mode to get the best times by utilizing the torque converter lock ability from gears 2 through 8.
MileHIFcar
GS F (2016-present)
01-13-19 07:52 PM
AshyAnklez
IS F (2008-2014)
114
01-01-16 08:03 AM
I8ABMR
IS F (2008-2014)
35
05-02-14 04:36 PM
