ISF Baseline Dyno Results
Old 10-01-08, 04:47 PM
Joe Z
Joe Z's Avatar
Received 1,063 Likes on 586 Posts
^^ Yeup.....
Should be close to Top Speed if I remember right... I got have the data pulled to double check the mph during our 6th gear pulls..
Jz
Old 10-01-08, 04:54 PM
caymandive
11 Second Club
caymandive's Avatar
Originally Posted by Joe Z
^^ Yeup.....
Jz
Indeed. Top of 6th is max speed of 170mph.
http://www.roadandtrack.com/assets/d...d/0108_ISF.pdf
Old 10-01-08, 07:09 PM
houstonT
houstonT's Avatar
Yes, mine was SAE corrected, here it is by RPM:
Here it is by MPH (almost 170):
Old 10-01-08, 08:09 PM
TherealFIG
TherealFIG's Avatar
Originally Posted by caymandive
Yes you do, especially if you plan on doing any mods in the future and want a fairly reliable baseline to measure off.
Maxing out 6th gear on that dyno is pretty safe. I'm getting a little nervous about my dyno session scheduled for Nov 1st on the dynojet.
While I would agree if I were in search of the peak number, I think I can take the same measurements (with this baseline held constant) and still weigh it on a percentage basis. Area of the curve and shape are what matters most to me and should to anyone looking at performance gains. Peak numbers will always vary IMO. I just wish I had done it while it was setup before for arguments sake.
Fig
Old 10-02-08, 12:37 AM
Joe Z
Joe Z's Avatar
Lightbulb
Hey Peter... anyway you can set these graphs with smoothing set to 5?? you will see a major difference....
Joe Z
Old 10-02-08, 05:46 AM
houstonT
houstonT's Avatar
Actually, not a major difference, rather a very small difference. Peak dropped by 3 rwhp.
Joe Z
Old 10-02-08, 07:51 AM
anajri
anajri's Avatar
Caymendive
I think the torque curve and the HP curve do not cross @5250 is because the torque axis and the hp axis are on different settings or values.... if this is not the case then forget this post
by the way congrast on your 1/4 time !!!!!
Old 10-02-08, 10:58 AM
Joe Z
Joe Z's Avatar
Interesting.. thanks for trying...
Our Dyno Jet runs in 6th gear repeated the same peak rwhp several times in the 333 rwhp range..
Which was basically an approx 20% loss in the drivetrain..
Jz
Old 10-03-08, 06:17 AM
LexISguy
LexISguy's Avatar
I just checked out the Hennessey website no longer mentions there ISF. Did they drop the project?
Old 10-07-08, 05:34 PM
TherealFIG
TherealFIG's Avatar
here is my dynojet run from today.
6th netted slightly higher peak, but 5th felt safer on the dyno at 175.
I would call the difference negligible.
scrosby
IS F (2008-2014)
17
04-08-12 05:42 PM
RRocket
IS F (2008-2014)
32
01-26-11 10:03 PM
PHXDiesel
IS F (2008-2014)
21
10-16-08 09:20 AM
Badman Forever
IS F (2008-2014)
13
04-21-08 02:01 PM
CrazyMPG
IS F (2008-2014)
03-05-08 06:33 PM
Quick Reply: ISF Baseline Dyno Results
