Wheels Setup For IS-F
Hi All ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
i need some help am planning to order Work wheels VS-XX 20inch for my IS-F and i need to know Width,Offset and tires setup to give an agressive look. i have Tein Coils to drop the car
Are you ordering them through a vendor or directly through WORK? WORK has the proper offsets and setup for the IS-F for their wheels. They should be able to give you a compatible fitment based on the size you want. All their wheels are custom built to order. So all you really need to do is say that you want 20" VS-XX staggered with your suspension setup, and the rest should be taken care of. The only caveat is that there's no way for them calculate the exact fitment because your suspension is variable, so you might have to take some risks there and maybe go a bit conservative.
What color is your F? And which VS-XX are you planning to get?
i have white IS-F and i like to order gunmetal color with chrome lip
and my frind living in Tokyo so he asked about the size etc.. and i like to have 285/25 or 295/25 in the rear so thats why am confused little bit
Yea if you are going with an unconventional tire setup + coilovers, then it's going to be really tricky. You might need a local shop that can test fit sizes for you, or you may need to contact WORK directly.
we can get you the perfect fitment on your F without a problem with 10.5" width wheels, just takes the right combo offset, pad hieghts, ect...
send us a PM for a detailed price qoute.
-Stefan@d2Autosport
-Stefan@d2Autosport
