Winter suitable wheels and tires???
I live in AB and it gets kind of nasty, anyways I was going to get winter tires, but then opted not to drive it in the winter. The is300 was bad enough.
Not to mention the window chips very easily ( i got a rock chip in the summer within the first 300km)
I went out and bought a 4runner instead.
Thanks everyone for the comments and suggestions!
After talking to the dealer and finding out that their intention was to put ISx50 wheels on my IS F, I have now ordered wheels and tires from tirerack.com. The dealership will be paying it and refunding the difference in cost. They will also be replacing the calipers that were damaged.
The new ones will look something like this:
http://www.tirerack.com/wheels/MiniW...dClar=&sw=1680.
I am a little annoyed that the intention was to put ISx50 wheels on. With the beautiful (and expensive!) BBS rims that come stock, why doesn't Lexus offer another IS F specific wheel option?
Thanks again everyone!
I found out later today that the wheels are not in stock and that I'll have to wait for them
BUT because of all the confusion...the dealer is going to provide me with 18" ISx50 wheels that apparently fit with my snow tires until the new wheels arrive. They messed up BIG TIME but are doing an admirable job to make up for it.
Did you go with 18x8 all around then? I had very good luck sticking with 255 rears the last 3 years. We even had about 100 inches of snow last year. PLUS, there's just a little more rubber to wear out so maybe you can get 2 full winter seasons instead of 1 1/2. I'm curious as how the dynamics will be with skinny rear tires. Let us know - I think you're the only IS-F with 225 rears that I've read about.
I bought the 225-40-19's. They are snow tires so I don't think I'll be pushing the car very hard. I'd imagine that these wear MUCH faster based on the compound. Hopefully they work well!
I decided on the Kosei K1 TS, nice racing wheel if I need to track it at 17lbs. I may PC them gunmetal And Michelin Xice Xi2 tires. It was so cold here today, it reminded me I needed to complete this purchase
Also 225 all the way around
Received 1,063 Likes
I went with 225/45/18 Bridgestone Blizzak LM 25's. Hopefully the narrower tire and higher profile will be what I need for the winter.
I know for sure the Spilt 5 spokes 18"s are a no go up front since the inner wheel barrel does not clear the calipers...
This could be a great solution for other IS-F cold climate owners.
- Joe Z
P.S. - Here is a thread that could have helped you with your prior caliper mis-hap. We did some testing back March 08'
IS-F 19" Wheel SWAP with 2IS 18" Wheel...& Big Brake Kit test fit as well.. w/pics
^^ Thats interesting.... Which 18" ISx50 fits???
- Joe Z
- Joe Z
I am unclear on what 18" wheels that they are going to try, but they are fairly confident they will fit. They are going to try mounting them on a demo IS F to make sure they fit this time....instead of wrecking my car again
Just so we're clear the wheels that they tried to mount are the F Sport:
http://www.lexus.com/models/IS/f-spo...oy_wheels.html
Ironically it was the exact opposite of your test! The wheels fit on the front, but there wasn't enough clearance on the rears and the calipers were badly gouged. The mistake they made was testing just the front wheels....and because they spun over the big 4 piston front calipers....they ASSUMED they would have more than enough room on the back....WRONG!
I'll have more info on Tuesday and post what they come up with!
^^^ Wow that is even more intersting...
So the 19x8 F-Sport Wheels clear the IS-F Front Brake system.. that is good..
Do you know what wheel they tried on the rear?? (19x8 or 19x9)
I would think the 19x9 F-Sport rear wheels would fit over the rear IS-F brake system.
- Joe Z
- Joe Z
Here is a picture of the LM-25's and the winter wheels I have. Having snow tires is certainly a peace of mind. I've been caught in many situations where I go in to work and it's sunny out and by end of day there's snow on the ground.
I think I may have found a cost saving option for using the OEM 19" wheels instead of paying for another set of wheels and tires. Good Year Eagle F1 All Seasons.
They have the OEM rear size available 255/35/19 $205 each
For the front I believe we can go with the 235/35/19 instead of OEM 225/40/19. $164 each
http://www.tirerack.com/tires/Sizes....+F1+All+Season
Yeah has anyone actually experienced if these tires will work with the OEM rims? If they do, I'll return my $3k worth of winter rims/tires to the stealership and put it towards something else. Anybody??
