Winter suitable wheels and tires???
#34
1) get an 18" 225 winter setup and hope whatever wheels I choose have enough clearance for the F brakes. I've narrowed it down to a couple of different wheels running Dunlop Wintersport M3s (great winter tire).
2) Goodyear 19" all seasons with 235s up front
Neither are a lock to work (perfectly) and unfortunately there's only one way to find out. I'll be rolling the dice over the next week but don't plan on having the dealer fit them until early December, so no feedback until then...
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#35
Rubbing during hard-over turns is my primary concern with running 235s up front. I'm looking at 2 options:
Neither are a lock to work (perfectly) and unfortunately there's only one way to find out. I'll be rolling the dice over the next week but don't plan on having the dealer fit them until early December, so no feedback until then...![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
235/35/19 Front
265/30/19 Rear
#36
but consider that the OEM wheels are 2K a pop up front and $2500 for the rears....I think the snow+rims is worth it. Just from the standpoint of curbing a rim will force you to buy a whole new set anyway for the money.
$1500 for my set of winter wheels and tires, not too bad.
Fig
Fig
#37
Fig
Fig
#38
I am also having a tough time to find a local shop in Vancouver, BC that will guarantee me any 18" wheel will clear the brakes on the IS-F. Most of them are saying the car is too new for us to commit to that.
I did go to the Lexus parts counter and they did say that they had a 18" wheel from the IS350 that would fit but I don't know if I can believe that.
I also want to go with a similar staggered setup with 225/45/18 for the fronts and 255/40/18 for the rears.
Looks like I will go for the TRMotorsport MT1 Matte Grey from Tirerack.com if I can't find a local guy to help me out.
Hope to hear some of you other guys with more options for me to consider.
#39
Toyo Proxy 4 all-season ultra high performance. These tires are lighter than the PS2 front tires and are slightly wider and lower in diameter for increased acceleration all the while costing $854 shipped. ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Toyo Proxy 4 vs Michelin PS2s
OEM Front
225/40/19
23lbs each
26.1" diameter
9.1" section width
OEM Rear
255/35/19
26lbs each
26" diameter
10.2" section width
Toyo Front
235/35/19
22lbs each
25.6" diameter
9.4" section width
Toyo Rear
265/30/19
26lbs each
25.3" diameter
10.6" section width
OEM Front
225/40/19
23lbs each
26.1" diameter
9.1" section width
OEM Rear
255/35/19
26lbs each
26" diameter
10.2" section width
Toyo Front
235/35/19
22lbs each
25.6" diameter
9.4" section width
Toyo Rear
265/30/19
26lbs each
25.3" diameter
10.6" section width
#40
James I think one downside to the toyo's is the loss of 3/4" of tire. That is something that will affect ride.
So did the PS2 come stock for most of you? mine has re050's on it.
#42
I currently have 225 40 18 up front (temporarily during drag racing season) which ends up being 1" shorter in diameter. More than anything, the front wheel gap really sucks. Ride height is 1/2 lower in the front too so I have to be careful of speedbumps. Once drag season is over, I'll be putting 225 45 18's up front to go back to stock "gap". I got PS2s - they're wearing pretty evenly - plenty of tread left and I'm at over 5K miles.
dchen2
08-28-07 02:53 AM
