IS-F Seats
Guys - I'm very close to pulling the trigger on an IS-F but the one thing that's holding me back is that the seats seem to be too small/tight for me. The side bolsters are TIGHT. Yes - great for the track but for daily driving? I'm a pretty big guy - 220lbs and after about an hour long test drive, my ribs were borderline sore. Anyone else have this issue/concern? Is there a solution? Do they break in? Thanks guys ... if I can get comfortable with this, I'll be joining the club.
I'm 6.0ft and 210lbs and the seats are great for my taste, actually I found them more comfy than the seats in my previous car, a GS450h (which were killing my back after a couple of hours).
Worst case scenario, I'm pretty sure you can swap the seats for standard ISx50 seats, I'm sure you will found a happy ISx50 owner willing to make the trade and give you some cash with it !
My brother complains about the seats sometimes too. He is somewhat of a widebodied person but I think in the long run they are more comfortable than a seat without the support.
I can understand where you guys are coming from regarding the seats. I have a normal build and it already holds pretty tight!
Do you guys get premature wear on the bolsters?
I'm only 5'8" 150lbs and I find the seats jsut right. I can only imagine you guys are crammed in there... there's not much room in the cabin as it is for even me!
I'm 5'11" 190 and the seat/back hits me about right...properly snug without feeling cramped. If you're on the edge comfort-wise, the seat should conform over time to a better fit. Oddly enough, it was this issue (and seatbelt rub) that steered me away from a G37 coupe. The thigh bolsters are too aggressive (and squats don't help
) making the seat portion uncomfortably narrow.
As far as side bolsters go, I always scuff the outside bolster because I'm not very careful in entering/exiting the car. I'm trying to rectify that with the F.
![Bang Head](https://www.clublexus.com/forums/images/smilies/banghead.gif)
Huh? There is a separate switch for lumbar, did you try it? It's fully adjustable and works very well. It's also memorized for the personal settings.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
