F Idiosyncrasies
I didn't like it either until I wound up with what we have now.. A system that makes you wait until the msg goes away before you can do anything. At least with the old system you could hit it instantly and you were good to go.
Also, the fact that they disabled the menu, volume trick bugs me.
I took a little trip to Gatlinburg, TN (first trip in F) this weekend and noticed another, pushing the "lock" button on the key fob a second time turns out the lights when they are left in auto. You can push the door lock twice and this does not turn them out, only when you hit the fob for the 2nd time.
Another thing that bugs me is that ISF doesnt stay in sport mode like my IS350 did.
Am i missing something or do you really need to switch into the sport mode every time you start the car?
Is there any way to keep it in sport mode all the time?
I've noticed that the material used on the doors shows marks very quickly (if your arm rubs across it or you brush it exiting the car). I am constantly having to wide the panel down.
Somebody needs to find way around it, it bugs the hell out of me
A few things I find very weird:
1. That display that shows "tire pressure" and stuff and its operation is very weird. I am not sure why they did not combine this with the display that shows gear number, MPG, etc.
2. Operating heat and A/C system is equally weird since you have the touch screen and some buttons that sometimes override what you did on the touch screen. Further, the A/C light (in the display) seems misleading. Sometimes when I get out of the garage and its 74F outside and my climate is set to 70F (but A/C off), I get cold air! I still have not explained this (it works the same on my Prius). How can I get cold air if the compressor is not running or is the compressor running even though the A/C light is off?
chrisfan
IS F (2008-2014)
19
10-11-13 07:35 PM
sammy5001
04-06-08 10:25 AM
