Rear View Mirror Vibration
11-18-08, 10:07 PM
My rear view mirror shakes / vibrating during freeway speed. Every now and then, it vibrates badly that I can't even make out the headlights behind at night. Normal for you guys?
11-18-08, 10:54 PM
I only get this with the audio on pretty loud. I assume your audio is off?
11-18-08, 11:35 PM
Only when the volume is past 45....or the needle is past 180 km/hr
11-19-08, 12:28 AM
Audio was on but volume was less than 25, I think.
Quote:
Originally Posted by
primecut
11-19-08, 06:18 AM
I get that sometimes but like everyone said, only with audio on. I would say tighten it up if you want, there is only one torx screw for the mirror so itd be a quick tighten
11-19-08, 10:00 AM
Will do. Thanks.
BigMikeISF
11-19-08, 10:02 AM
I have the same issue - audio on or off. Would you please post if the tightening helped? I'll try that on my car when I'm home next.
11-19-08, 10:08 AM
i have the same issue, everything shakes/ bumpy in the isf in highway speeds when the roads are all the way flat even minor bumps you can feel
05-02-11, 01:59 AM
Curious whether any of you got the TSIB upgrade for this and whether it's helped?
05-02-11, 07:39 AM
05-02-11, 03:05 PM
Lexus Connoisseur
I did and I was the first to get it done for a 2009. It helped immensely.
05-24-11, 09:03 AM
If you have the stereo volume high this is not uncommon other wise I woulod just try to tighten the screw to secure it better
05-24-11, 10:36 AM
Lexus Connoisseur
JREP
Its not that easy. Theres already a TSIB to correct this issue with a mirror assy replacement.
yardie876
LS - 5th Gen (2018-present)
11-04-17 08:33 AM
IS350atWOT
ES - 6th Gen (2013-2018)
07-08-13 06:23 PM
randomwalk
01-15-11 04:16 PM
2000 ,
2008 ,
controlling ,
is250 ,
lexus ,
mirroe ,
mirror ,
model ,
rear ,
rearview ,
rx330 ,
screw ,
size ,
torx ,
trox ,
vibrate ,
vibration ,
view
