Jumpy gears when cold
My F is also a bit 'jumpy' in the 1-2 / 2-1 shift for the first bit of driving on these cold mornings (even after warming up at idle for a minute or so). Doesn't seem to be anything worth worrying about.
What mode are you guys in when you're having this problem...automatic or manual?
Every car is jumpy with a cold engine pretty much. My last car even prevents you from reaching a certain RPM if the engine temp isn't high enough. Drive easy for the first 5 minutes on a cold morning to let the car warm up.
