Brake Calipers
[QUOTE=CaThaFeR;4037987]definitely get them powdercoated if you are going to do it.. i had mine done the day after i picked my car up
QUOTE]
Your calipers are beautiful! May I ask, did they have to remove the calipers from the car and even rebuild them after powder coating them?...Darshana S...
Well according to Lexus, it's $832/caliper, so be very careful where you take them to be painted. Because if deassebly causes failure that's an expensive fix. Still thinking about diong it though however...
2IS OG
I've never done this, but I wanted to pass along a bit of advice that the engineers at Brembo gave me. The advised me to NEVER powdercoat a Brembo caliper (they themselves don't powdercoat their calipers, they paint them). Brembo calipers are not designed to be rebuilt, and the extreme heat that the powdercoating process requires could damage the components of the caliper, negatively affecting both its functionality and durability. Just an FYI for you guys considering this...
Javier
Javier
Javier
Javier
Tech Info Resource
Javier
Javier
Ah...answered my own question - the procedure specifically says DO NOT REMOVE THE PISTONS FROM THE CALIPERS. The seals are just the boots, not the piston seals.
Received 1,063 Likes
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
So if you shouldn't powder coat them, then just spray paint them via DIY or professionally by a body/paint shop... ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I agree, Powder coating is nice an all, but some times it adds 1-2 mm of thickness on material or components that do not have much clearance to begin with.
Joe Z
Joe Z
Studiogeek
SC- 1st Gen (1992-2000)
06-09-14 08:05 AM
