just got my DRL LEDs lights for the IS-F (9005)
They are designed that the middle must first be pushed in slightly to release a lower (unseen) clip.
Then you can either pry or grab with a fingernail the sides of the larger plastic part to remove.
Once out, push the middle (smaller) section back and out. Re-install the larger section first carefully so that the body of it fits well into the hole and then slide the smaller (locking) middle section into the lower section to lock.
It's locked again when flush with the larger base section.
C.
Well, they run in full power (high beam) mode all the time thanks to the module, so they are brighter when they are DRL's. When used as high beams, they are probably not as bright as stock. I used them the other night, and I was actually surprised at how effective they were as high beams. I was pretty sure they were just going to be for show, but they DO work.
wiper fluid reservoir
tall standpipe from the reservoir
dust covers
swinging silver bar
Low Beams cover
wiring harness
these term u use in your guide, can u define them with pictures?taken from is-F? because i dont have a clue.not words... i am a visual learner.
i am a real noob
thank u
dust covers
swinging silver bar
Low Beams cover
wiring harness
i am a real noob
thank u
dust covers
swinging silver bar
Low Beams cover
wiring harness
i am a real noob
thank u
dust covers
swinging silver bar
Low Beams cover
wiring harness
i am a real noob
thank u
What you are probably asking for is a shot of what they look like on vs. low beams only on. I'll take a shot of that over the next day or so as well and post it up. As I mentioned up above somewhere, I was quite pleasantly surprised at their High Beam power... I really didn't notice much (if any) performance decrease using them in the real world vs. the stock bulbs.
I was wondering if anyone could help me out. I just bought fog lights and high beams/daytime running lights. I've heard about that wiring harness thing necessary for the high beams so the daytime running lights are always at full power. I'm just not sure if that's necessary for all brands of lights. The lights i bought are....
fog lights = PIAA Plasma Ion Yellow H11 55W
high beams= PIAA 9005 Super Plasma GT-X
In the description of the 9005 super plasma gt-x high beams, it says "PIAA GT-X replacement bulbs are designed with an exclusive purple low beam and an Xtreme White high beam."
Does this mean it's a straight install swap? And I don't need the wiring harness thing.... thank you for anyone who can help. Whether I bring it to lexus to have the lights installed or do it myself...i just want to make sure they are done right the first time. And I don't run into a problem because that wiring harness thing wasn't installed. thanks
