JIC Magic FLT-TAR coilovers on IS-F
Old 12-13-08, 10:53 PM
CrazyMPG
Phat Monkey
CrazyMPG's Avatar
haha congrats on getting the JIC Coilovers!!! Hope you enjoy them as much as I do...it is night and day compared to the stock suspension! Hope I was able to help you out with all your questions.
Old 12-13-08, 11:04 PM
oztiks
oztiks's Avatar
Originally Posted by Robs IS250
where in FL you located?? you gotta show Hi Profile's IS-F handling n ride quality so they can get it! LOL
South Florida - West Palm Beach area. If they want to make a trip..
Old 12-13-08, 11:05 PM
oztiks
oztiks's Avatar
Originally Posted by TherealFIG
so you wanted to make it softer? I would not mind a stiffer spring rate with more damping adjustment. It does get hoppy in some road surfaces, but the spring rate seems too soft for my taste also. I dunno, gotta play with it.
Are you referring to the JIC's or the stock ride?
Old 12-13-08, 11:06 PM
oztiks
oztiks's Avatar
I'm freaking lovin' them, and thanks again for your help!
I went from 6->8 all the way around today, found the ride to be a little too harsh. Dialed it back to 7 for now. Seems better.
Still having the slight rubbing issue on the front left ONLY.. not sure what the deal is there.
Old 12-13-08, 11:09 PM
iSuxeL
iSuxeL's Avatar
Slam that bish!
Old 12-13-08, 11:23 PM
oztiks
oztiks's Avatar
Originally Posted by iSuxeL
Slam that bish!
Already rubbing up front! Don't think i can go any lower.
Old 12-13-08, 11:38 PM
crilla
crilla's Avatar
Ahhh that looks really good.
Old 12-14-08, 08:44 AM
oztiks
oztiks's Avatar
Anyone have any recommendations on diagnosing the rubbing issues in an easy manner?
Old 12-14-08, 08:47 AM
iSuxeL
iSuxeL's Avatar
Jack up your car and look at the fender lining and look where it shows rubbing. Most likely its the same spot as us ISx50 guys. Its where the fender meets the bumper, but for now just get a heat gun and push back the fender lining. Stretch your tires a bit and slam that bish!!
Old 12-14-08, 08:50 AM
oztiks
oztiks's Avatar
Is it common for it to only happen on the front left, or do the other IS-ers get it on both sides?
Don't think im quite willing to stretch the tires
Thanks for the help!
Old 12-14-08, 08:53 AM
iSuxeL
iSuxeL's Avatar
If its rubbing on one side there's a slight chance that side is a bit lower IMO
Old 12-14-08, 08:59 AM
oztiks
oztiks's Avatar
That's what I was thinking.. will try and get that checked out on Monday.
Old 12-14-08, 12:21 PM
Robs IS250
Robs IS250's Avatar
we drive on the left thus leading to more weight on the drivers side... thats my theory of mainly rubbing on the left and im on springs!
Old 12-14-08, 02:53 PM
oztiks
oztiks's Avatar
That was kind of my (very un-scientific) opinion as well.. I'd like to think my < 200 lbs doesn't affect the car that much, but I guess it's possible. If I'm running with such a limited tolerance up front, though, then I definitely need to get both sides raised a bit ( )
Old 12-14-08, 05:33 PM
Robs IS250
Robs IS250's Avatar
LOL wear those fender liners thru!! You know i got you whenever you come to L of West Kendall
Quick Reply: JIC Magic FLT-TAR coilovers on IS-F
