MHP ECU/TCU Thread (updated with v1 gains: Graphs/Spreadsheet Breakdown)
#182
#185
BTW, would you ever consider selling the WHOLE thing? ECU with the tuning on? I'm aware it'll cost more, but if it's as easy as swapping ECUs (I'm assuming it's just a plug and maybe some screws?) I'd gladly buy it and install it and later on, I can just swap it and sell the "tuned" ecu to another IS-F guy.
I'm assumining you're working on some sort of intake box/gasket also hence the question re: Ohio and Maryland.
#186
#188
Andy,
Are the ECU (Engine Control Unit) and TCU (Transmission Contol Unit) contained within a single unit are or they separate? If we were to buy a spare VIN synched ECU would that be sufficient?
#189
Andy,
I just sent you all 3 raw WinPEP dyno files. They were done in 6th gear, so confirmed it was a 1:1 gearing. For the records traction control was OFF and in SPORT mode.
The numbers vary from SAE to uncorrected, and from 0 smoothing to 5. Here are some graphs that show this:
UNCORRECTED - SMOOTHING 0: 360.61 RWHP / 354.73 ft-lbs
![](http://63.84.173.65/temp/uncorrected-0.gif)
SAE CORRECTED - SMOOTHING 0: 351.73 RWHP / 346.00 ft-lbs
![](http://63.84.173.65/temp/sae-0.gif)
SAE CORRECTED - SMOOTHING 5: 349.34 RWHP / 344.54 ft-lbs
![](http://63.84.173.65/temp/SAE-5.gif)
Last night I drove all the way to Moroso (looooong drive) and what a nice racetrack! My plan was to do all my runs in the same way I drive my car on the road, that means full interior (didn't remove the spare tire or jack), without lowering the tire pressure or switching tires. Since we don't have launch control (hint Andy, you can make this happen as well) I was thinking about launching at 1000 RPM and keep increasing the revs in following runs so I can find the perfect spot. Well, things didn't go as planned because after my first pass the track crew decided to not let me go again until I get a helmet, they said my times require a helmet. Of course I didn't have one, and they don't rent them, so I drove for more than 3 hours, 200 miles, and got only one pass. I wasn't bad anyway, here are the details:
R/T: ---- 0.175
60': ---- 2.083
330: ---- 5.584
1/8: ---- 8.426
MPH: ---- 87.14
1000: --- 10.849
1/4: ---- 12.800
MPH: ---- 111.42
If this is good enough I can ship the ECU as soon as I get details about how to remove it, otherwise I'd have to wait until next weekend to get more passes.
R/T: ---- 0.175
60': ---- 2.083
330: ---- 5.584
1/8: ---- 8.426
MPH: ---- 87.14
1000: --- 10.849
1/4: ---- 12.800
MPH: ---- 111.42
#190
Juanca how much fuel was in the tank? Were you shifting with the paddles? BTW welcome to the TOP 5 club. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Drag Strip Journal
Drag Strip Journal
#191
if everything goes well with this... this car will literally be one of the fastest street cars! for the price (in most cases already is)...
faster then all but 1 model of aston martin, a handful of Porsche's, bentley's, jaguar's.. ect ect
#192
Top 5? I had no idea, thanks. ![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
I had around 3/8 of fuel in the tank, and I used the paddles. At what RPM do you launch your car? I had no chance to try different leves.
Drag Strip Journal
Drag Strip Journal
#194
R/T: ---- 0.175
60': ---- 2.083
330: ---- 5.584
1/8: ---- 8.426
MPH: ---- 87.14
1000: --- 10.849
1/4: ---- 12.800
MPH: ---- 111.42
R/T: ---- 0.175
60': ---- 2.083
330: ---- 5.584
1/8: ---- 8.426
MPH: ---- 87.14
1000: --- 10.849
1/4: ---- 12.800
MPH: ---- 111.42
That's satisfactory for us, you really went above and beyond to get things done quickly and it is highly appreciated!
We're ready for your ECU. If you still need removal instructions let me know and I'll call you tomorrow.
Thanks!
Andy
#195
Thank you sir! That's the money shot right there. ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Thanks for putting the time in, and get a helmet you only have one noggin!!!
Thanks!
Andy
Thanks!
Andy
My Lex. isn't as familiar to me as other rides I've had..
Cheers
Colin.
