Tire Wear Question
Old 08-29-10, 09:13 PM
  #46
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,978 Likes on 2,406 Posts
Originally Posted by ES3
Have you done many adjustments on alignment to your F to prevent abnormal wear?
There's a thread about all of it. But no, not many since it wasn't as horrible from the factory as some others here have experienced.
Old 09-10-10, 12:54 PM
  #47
ES3
ES3's Avatar
It's the toe. Camber isn't usually a problem until you exceed -2.5 degrees. Mine came from the factory at -1.0. I run my Supra at -1.5 on all four corners without any wear issues at all.
Get the toe right and all will be well.
It seems there's a LOT of variability in the factory's alignment for the 2IS models. My 350 wore tires perfectly except for my driving. My F has not, despite my driving.
What is your toe set at? Same as stock?
I'm going to the dealer tomorrow and want them to come up with a toe that will midigate inside wear up front. Haven't noticed abnormal wear on my rear, is that common for any of you here?
Old 09-10-10, 01:12 PM
  #48
ES3
ES3's Avatar
This is complete hogwash. No modern car has positive camber. See attached for IS-F alignment specs: (Also note the toe in specified at the rear is identical to the MkIV Supra spec, and I found it to be an inside edge killer so I came up with these specs.)
Is this attached image the Lexus specs? Or the alternative that will reduce interior wear?
Old 09-10-10, 06:12 PM
  #49
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Lexus specs. Properly implemented, they work fine.
Old 09-10-10, 06:37 PM
  #50
LexISguy
LexISguy's Avatar
I managed to get 35,000 miles off my first set of tires. They were the Potenza's.
Old 09-14-10, 01:00 PM
  #51
ES3
ES3's Avatar
Mine were within spec, but definitely bald on the inside. Is it possible that those who are needing the camber kit to help with pull to one side, may also need to adjust camber to prevent balding? Or should camber not be associated with baldness.
Old 09-14-10, 01:55 PM
  #52
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Camber at the small angles we have is not associated with the type of wear we're seeing. Everything points to toe adjustment, and with the 2IS chassis, subframe positioning and toe are the two things we're consistently seeing the factory getting just enough wrong to cause premature tire balding.
Within spec is not good enough. The numbers need to be ON spec, not just showing green on the alignment computer. You could have quite a bit of toe out in front, balding inside edges in 15k miles, and still be within factory specs.
PatDowdNC
04-16-23 06:36 PM
filmteknik
08-16-16 02:43 PM
NoLongerA13bFan
Wheels, Tires & Brakes Forum
03-04-08 04:33 PM
Quick Reply: Tire Wear Question
