Eibach springs feedback?
I know there are a couple of guys/gals running the eibach springs on there "F". I am looking into installing these on mine as well, but before I do that I would like to get some feedback from the people running them on:
Ride Quality:
Any abnormal Tire Wear:
Effects on Handling:
Overall Opinion:
Thanks in advance!
Ride Quality:
Overall Opinion:
Thanks in advance!
As far as springs can tell you on the IS-F, I don't have a clue. However the Eibach's on my 250 rode nice, but wore out quickly. By the time I traded in my car, which had to be only 4k miles on the springs themselves the entire car drove very hard and bumpy.
Don't go springs on your F...go coilovers!
I just installed these a few weeks ago.
Ride Quality: Same, When coming from the IS250 I noticed that stock it was bouncier, so with the new springs i did not notice any change.
Any abnormal Tire Wear: I have not noticed any different tire wear YET, I only had these on for a few weeks.
Effects on Handling: I noticed turning on the toll road, there are some turns on there that I would have to let my foot off the gas, because i felt the back end lunging, on those same stretches I can keep the hammer down. Not sure if it is in my head, but seems to have better cornering/handling.
Overall Opinion: For the price they are great, I can not go much lower do to my garage entrance / alley way. So right now Coil-overs were not an option. They installed with no problems, and the dealership didn't say anything to me about them when i went in for my 1000 mile service.
another point I wish the front was a little lower, but the back sits nice.
Well I have been a driver and passenger in Crazympg's IS-F both before and after his coilover install...
I can tell you for sure coilovers will clean up that temperamental bounce found on the IS-F OEM suspension and even my IS350 with OEM Sport Suspension.
Coils will give you the ability to setup a dead even perfect drop and adjust dampening to your liking..
If you can swing a coilover setup, that is what I would recommend in my honest opinion..
If not, Eibach springs should work well..
(but I have zero feedback to give you on aftermarket springs in general)
Joe Z
Have had Eibachs in the NSX for years and they still ride great.
Arguably, they ride BETTER than stock when coupled with good struts/shocks (the NSX has Bilsteins).
My brother also ran Eibachs in his GS300 for a couple of years, rode and performed great (although the drop was very subtle, 1.25")
Eibach is one of the best spring manufacturers out there, in my opinion.
But the IS-F isn't a cheap car, and if I were to lower one I'd prefer to use coilovers.
Also, Ryan needs to lower his IS-F.
Good quality springs like Eibachs don't "wear out." More than likely you were noticing some other element like worn OE shocks or tires.
I'd agree that coilovers are the way to go, but something hasn't been mentioned here. Coilovers are a lot of work to maintain and more importantly tune. If you don't know how to tune the suspension properly you're really going to affect the way the car handles (usually for the worse) at or near the limits. People generally do the best "guesstimate" to dialing in the suspension for damping and ride height. I'd suggest going for corner balancing and getting some help from someone who knows what they are doing... just my 2 cents.
I PUT ON THE EIBACH SET ON MY F TWO MONTHS AGO.....SURE HANDLES BETTER ON TURNS THAT WAS THE FIRST THING I NOTICED AND THE RIDE FEELS THE SAME IF NOT A LITTLE SOFTER....BUT THE HUGE GAP IN FRONT IS ALMOST GONEBACK SITS PERFECT IMO WISH THE FRONT WAS A TAD LOWER BUT THE OVERALL EFFECT GIVE THE CAR A "WIDER MORE MEANER LOOK"
ESPECIALLY WHEN VIEWED FROM THE FRONT SO FOR THE PRICE U CANT GO WRONG AND FOR ME COILOVERS AREN'T WORTH THE PREMIUM UNLESS UR GONNA GO OUT TO THE TRACK MY F GOES FROM HOME TO WORK SO IT WAS A SIMPLE CHOICE GUESS IT GOES DOWN TO PERSONAL CHOICE.
