Official IS-F Drag Time/Dyno Time/Performance Thread
#241
looks like the most important thing i see is to have a 330 time below 5.60 in order to get a run in the low 13's or high 12's my question is how much time will you save in the 330 if you have all trac aid's off along w/vsc in sport mode vs. just manual shifting in sport mode
#242
I just got a is-f you all are talking about intake heat soak? not really sure what intake to buy now or just leave the stock one... any help will be greatly appreciated because I plan on buying a intake within the next couple days just don't know which one
Thanks!
Thanks!
#245
Yep, Joe-Z all the way. All I have is the Joe-Z intake with an AFE Pro Dry filter. I got a 4.1 0-60 time using GPS.
Notice that the CCS-R is using a very similar intake. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
https://www.clublexus.com/forums/is-...rom-ppihc.html
#247
Tech Info Resource
Sport, VSC off, manual shift on the beep. 13.2 - those must be some heavy wheels. What was the trap speed?
#249
Tech Info Resource
That's a really low trap. Should be at least 110. The wheels are the right diameter, but they must be really heavy and at 20" they're heavy where it hurts most.
#252
Hi Guys - i am new to the forum and i am from Bulgaria , Eastern Europe but we have very few IS-F's here since audi and bmw are king on this side of the world. Anyway to the question:
I was doing some drag times with my 2011 Is-f and i am disappointed to say the least!
The car is bone stock including the Michelin tires. I was doing 13.6 to 13.7 consistently all day.
Now what i want to know is how much the weather affects the drag times since outside was reallyyyyyyy hot i mean burning! 30-32 degrees Celsius which is around 90 in Fahrenheit. Also the track itself stands on 860m above sea level. Could those two things be the reason ?
Also what kind of preassure should i use on the tires ? Right now i am on max since i was doing 270 km/h going back and front to the seaside![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
But i am thinking that i have too much wheel spin on the starts even though my reaction time is 0.180 - 0.200 which again might be too much.
I am using sport mode, vsc off (i am pressing the button until all two traction control lights go on) and manual shifting untill beep.
Please help! I am going back tomorow without a spare and low gas hopping for atleast a low 13
Any help is appreciated!
p.s. and i cant make a decent start since reeving above 1000 rpm makes huge wheel spin.
#254
