Official IS-F Drag Time/Dyno Time/Performance Thread
Old 09-29-17, 05:14 PM
  #691
jat0223
jat0223's Avatar
Your trap speed is very low even with that 60'. Are you really mashing the pedal? How many miles are on your F? Was this run at altitude? Depending on your altitude and track conditions, you're trapping about 10mph below what you should be trapping, this is substantial and might indicate a problem.
Old 09-29-17, 05:47 PM
  #692
FFM
FFM's Avatar
Yeah good catch. Perhaps your KCLV was crap? I run some octane booster for a few days to make sure there’s no chance of knock before I head to the track. Just enough to push our 92 to about a 94.
Ill have to look again but I believe i was trapping around 110-112
Old 09-29-17, 07:55 PM
  #693
FNSSESPORT
FNSSESPORT's Avatar
I actually thought the same thing, especially after the first run I thought maybe I hadn't mashed the pedal far enough down. So after the first run I made sure I moved my seat up, and I definitely had the pedal to the floor. And no, pretty much sea level.
I usually put in 91 octane from Shell (partly due to the fact that it's the only gas in Canada that doesn't contain ethanol) and have done this since I bought the car. I bought the car at 60K kms and it's now at 112k kms. This week I decided to switch to Petro Canada 94 Octane. It could be my imagination, but it feels better. Is TECHSTREAM the only way to check KCLV?
Old 10-02-17, 12:54 PM
  #694
JDMV8
JDMV8's Avatar
There are bluetooth OBDII devices that stream data to your phone! Some have been posted around the forums
Old 10-04-17, 12:50 PM
  #695
Joker4096
Joker4096's Avatar
I don't believe that any of the Bluetooth adapters along with aftermarket software can log the kclv. I am pretty sure that it is only viewable in Techstream software.
Old 10-21-17, 10:25 AM
  #696
ForzaF
ForzaF's Avatar
Went to the track last night and had the pleasure to slay a c63 amg 4 door 15deg Celsius nice and cool night.
Old 10-21-17, 06:37 PM
  #697
SoulFreak
SoulFreak's Avatar
Nice run! Any mods done to your F?
Old 10-21-17, 07:06 PM
  #698
ForzaF
ForzaF's Avatar
In my sig you will see my mods . Exhaust, joez intake elbow,afe dry/ ran on nitto nt05r drag radial 275/40/17 just tried them out as I sold my Hoosier setup as I thought I'd be done going to the dragway but apparently not and bought my brother in-laws setup when he sold his F.
Old 10-21-17, 07:42 PM
  #699
SoulFreak
SoulFreak's Avatar
Thanks for the reply. I'm on mobile and wasn't able to see your signature, I apologize. Interesting setup, I definitely want to try an ideal drag radial setup one day. I did have virtually the same results as you with exhaust and upgraded MPSS 245/275 on stock 2011 wheels.
Old 10-23-17, 03:39 AM
  #700
ForzaF
ForzaF's Avatar
Yeah I think there is more in the drag radial to get out of as in terms of hook up when you have more power like headers, when you add extra 40whp the stock tires will break loose quicker with headers or full bolt ons with the rr-racing tune and intake. I've had similar results before hooking up on my pss as well as the hankooks rs3. I wanted to play with air pressure at the track as my tires were inflated to max spec for driving there. But I noticed air wasnt available so i couldnt do any tire testing and trying to drop my 60ft times by softening them up and hopefully launching better out the hole. Also because its pretty much end of the season here for drag racing there was no track prep and my times in the left lane were much worse due to coolant spill from another car and all they did was mop it up lol. My 60ft were 2.3 in that lane as i would experience wheel spin.
Old 10-27-17, 07:45 PM
  #701
v8sedan
v8sedan's Avatar
Default New best
Ran 12.55@113 tonight . Need dr to do better but still happy. Hps intake borla exhaust . Need rr tune too now 😁
Old 10-28-17, 09:46 AM
  #702
FFM
FFM's Avatar
1.9 60’ ain’t bad though. But yeah, getting that down even two tenths would give you a very solid run.
Im leaning that direction for next year.
Old 10-28-17, 12:39 PM
  #703
v8sedan
v8sedan's Avatar
Tanx ffm. I think i'm gonna go with the tune before dr cause it's more effective. Usable on the street and on the track 👍waiting for CAD$ to climb to order it .
Old 10-28-17, 12:44 PM
  #704
v8sedan
v8sedan's Avatar
Did small burnout at the beginning but found that the nitto needed a 2nd gear burnout to hook. Got from 2.2 to 1.9 heating the tires more .
Old 10-28-17, 06:33 PM
  #705
Gymkata
Gymkata's Avatar
I had my ISF dyno'd at the Sikky Block Party today on their Dynapack. I don't have any baseline to compare it to so the numbers don't really mean much. I'll take it though. I last dyno'd my ISF on Sikky's dyno back in 2012(?) with JoeZ intake pipe, Sikky headers, and Borla exhaust. It put down 405 whp. 5+ years later with the addition of RRracing intake box and tune, it put down 430+whp. Once again it isn't an apples to apples comparison so it doesn't mean much. The block party was a blast though.
Attached Thumbnails Official IS-F Drag Time/Dyno Time/Performance Thread-20171028_134751.jpg   Official IS-F Drag Time/Dyno Time/Performance Thread-isf-dyno-oct-2017.jpg
Quick Reply: Official IS-F Drag Time/Dyno Time/Performance Thread
