Official IS-F Drag Time/Dyno Time/Performance Thread
Old 03-24-19, 07:24 PM
  #766
1sFTW
1sFTW's Avatar
Originally Posted by FFM
Wonder how much power the VR tune adds?
I’m not too sure, closest dynojet to me is an hr away, so, doing mods individually then seeing their effectiveness is inconvenient. When I make it out to the dyno next week, I might flash the stock tune then flash the VR and compare. My butt dyno told me that it took about a day for the VR tune to “kick in” so idk.
Old 03-24-19, 08:02 PM
  #767
mike33
mike33's Avatar
The problem with flashing between tunes at the dyno is the KCLV ( knock correction learned value) will reset to 15, this will result in the pcm pulling timing to prevent detonation and a loss of hp. If you have not measured your KCLV, I would reccommed you do so, when it gets to the 24-25 level you will be getting maximum ignition timing and hp. There are ways to get the kclv to the maximum, but it takes time for the pcm to learn.
Here is a thread discussing this issue.
https://www.clublexus.com/forums/is-...highlight=kclv
Old 03-24-19, 08:19 PM
  #768
1sFTW
1sFTW's Avatar
thanks for the link, good read. It makes sense to me, I just couldn’t explain the reasoning for the ecu needing to “learn” the modifications. Not going to reflash for the dyno then for time/money. If I had a plethora of disposable income, easy day. I will dyno with the mods I have now to compare to my stock!
Old 03-28-19, 05:15 PM
  #769
BirgeyT1
BirgeyT1's Avatar
Went to the 1/8th mile Friday. Was 71 degrees with a DA of 1700. Rr tune, intake, gutted stock headers and PPE exhaust. 18 inch Volks, 285/30 advan a048, 1/4 tank and no spare or tools.
Old 03-29-19, 01:45 PM
  #770
mike33
mike33's Avatar
BirgeyT1, thats a very good 1/8th considering a DA of 1700... Is that the first run you made with the poly bushings in the rear diff and did you notice an improvement in traction with them?
Old 03-29-19, 02:29 PM
  #771
BirgeyT1
BirgeyT1's Avatar
I never ran without them in this car but I did in my first ISF and that one would wheel hop really bad. With the poly bushings I did not get any wheel hop but I don't know if I'd really say they improve traction.
Old 03-30-19, 08:04 AM
  #772
Jwconeil
Jwconeil's Avatar
That is good. My best 1/8th was 8.23 so far. It yielded a 12.65 quarter.
Old 04-08-19, 05:23 AM
  #773
1sFTW
1sFTW's Avatar
Default Drag Time Update
Update on some times. This is at the track running 4.29 gal of E-85 and 9.88 of 93 oct. My ECU doesn’t have a flash for the blend, but since I blended, KCLV went from 17.8 to 21.5 while logging with the tonwon and OBD Fusion. Still on 255/35 Michelin Pilot Sports A/S 3+ With about 50% tread. I’m Car #13.
Car #13
Corrected DA.
Against the new Mustang GT A10. Driver MOD
The following 3 users liked this post by 1sFTW:
BirgeyT1 (04-09-19), lobuxracer (04-08-19), mike33 (04-08-19)
Old 04-12-19, 09:04 PM
  #774
BirgeyT1
BirgeyT1's Avatar
Made it out to the track last night on the drag radials. DA of around 1750, 20 mph headwind. My first pass was my best pass and probably would've been a high 12.1 but of course they had just reset the timing and it only gave me my 1/8th mile. Second pass was my second best and netted a 12.23@115.1. With the DA corrected (pic attached) it looks like I would've gotten my 11 After that the track got slick. This was under a 1/4 tank, long press off on TC, sport mode, manual shifting. Also, question for you guys. I can't for the life of me get both wheels to spin on the burnout so what's the trick? Car is a 2008 but I don't see others having this issue. Do I need to shift into second on the burnout? Also, is this a record for stock headers? I've also attached videos of the burnout and the 12.23 run as attachments where you can see only one tire spinning. Mods are as follows:
RR Racing Tune
RR Racing Intake
Gutted stock headers PE catback with muffler delete
17x8 +35 rear wheels w/ 245/45/17 Hoosier DR2's
no tools/spare/engine covers
File Type: mov
File Type: mov
Old 04-13-19, 12:05 AM
  #775
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,972 Likes on 2,403 Posts
Those are mighty fine numbers for the stock header - does it still have the cat inside or have they gone the way of the dinosaurs?
Old 04-13-19, 08:12 AM
  #776
BirgeyT1
BirgeyT1's Avatar
Updated my post!
Old 04-13-19, 01:13 PM
  #777
lobuxracer
Tech Info Resource
lobuxracer's Avatar
The '08s have an open diff from the factory and the eLSD doesn't kick in at burnout speeds. If you really want both to spin, you need some kind of LSD spool like the '10 and later model Torsen. Poor man's LSD is to put the parking brake on just enough to imitate a clutch type LSD. I've done that when stuck in other RWD cars. Not sure how great it would be for a full burnout though. I permanently solved this with a Giken TCD. Huge difference in how the car performs compared to the open diff.
Old 04-13-19, 01:40 PM
  #778
BirgeyT1
BirgeyT1's Avatar
Thanks for the info. Would the Cusco diff make the same difference as the Giken or is the giken superior? Speaking from a strictly drag racing standpoint.
Old 04-13-19, 09:49 PM
  #779
Jwconeil
Jwconeil's Avatar
I think Caymandive’s 11.90s passes were on stock headers, but I don’t remember. I may be wrong.
Old 04-13-19, 09:50 PM
  #780
Jwconeil
Jwconeil's Avatar
Birgey, did you just roll out or load the driveline? Your times are good.
Quick Reply: Official IS-F Drag Time/Dyno Time/Performance Thread
