JoeZ Exhaust and/or Intake Owners..?
#33
^Well I'm glad I'm not the only one who had a drop in tank average ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Has anyone else who installed the Joe Z exhaust painted the tips black? Not the stock tips on the car but the Joe Z exhaust ends? I think a few have done this and am curious if others are following suit. It is supposed to hide the exhaust better.
#36
It'll be hard to keep one's foot out of it tho, unless highway cruizin', with such sweet 'music' on tap.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
C.
#38
Everything you want is here:
https://www.clublexus.com/forums/is-...-for-is-f.html
The search function is a wonderful thing.
Lou
Lou
#39
for those of you that got it, how hard was it to install? can you do it in your garage?
also on the www.CarsonTuned.com it says that the cats dont come with it, i guess you reuse the stock cats then?
#41
Lou
#42
pardon my complete ignorance on the subject, but i even resorted to google...
WHERE DOES ONE BUY THE EXHAUST AND INTAKE?
A private message will be fine - no need to tell me to "use the search feature..." - i've already tried that
TIA
doug
TIA
doug
#43
Still a great buy.
Luis Salazar will be glad to look after you.
https://www.clublexus.com/forums/clu...e-08-is-f.html
Colin.
#44
LX470man,
It is probably possible to do it in your garage but I would suggest that you find a lift so that you can work on it much easier. It took us about 1.5 hours to remove the old exhaust system and install the new one.
You will need the short oxygen sensor socket shown in several of the threads discussing the JOE Z exhaust system.
It is a complete bolt in system and the fit up was excellent. You will need to use a lubricant, such as WD40 to lubricate the rubber hangers when removing the old exhaust sytem. It is, more or less, a brute force removal. You will need either large screw drivers or a pry bar to pry the rubber hangers off the conical end caps on the OEM hangers.
Pat
Pat
#45
LX470man,
Pat
Pat
I agree with what Pat said regarding the install, you can do it, just make sure you have room to get under the car and to remove and reinstall the exhaust as well as you have the right tools handy.
I used a lift at a buddy's shop to do the install and it worked perfectly. There is an entire thread on the O2 sensor removal tool that you need to be able to safely remove, well, the O2 sensors
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
