Widest tires on stock wheels
Old 03-12-09 | 07:59 PM
Isfast's Avatar
Isfast
Default Widest tires on stock wheels
Anyone know the widest tires on stock wheels front and rear without rubbing and minimal speedo error. Thanks.
Old 03-12-09 | 09:12 PM
btwanky's Avatar
btwanky
from what i heard.. its possible to do 275... when i got a flat.. the guy said it was most likely possible
Old 03-12-09 | 10:38 PM
lobuxracer's Avatar
lobuxracer
Tech Info Resource
It's possible, but with a 9" rim, it's a little on the tight side. Ideal rim width is 9.5"
Old 03-13-09 | 05:28 AM
caymandive's Avatar
caymandive
11 Second Club
You could do 265/30/19. There also appears to be more choices in that size than with 255/35/19. With the 2% gearing reduction you'd have slightly quicker acceleration, but also have a slightly larger wheel gap or go with 265/35/19 which is only 1% higher gear increase and would slightly fill the rear wheel gap. 275 width on a 9" rim is just too much IMO.
Old 03-13-09 | 10:13 AM
btwanky's Avatar
btwanky
what do you mean gear increases and decreases?
Old 03-13-09 | 10:25 AM
Cabinetman's Avatar
Cabinetman
When you go with a taller tire than stock you effectively lower your gear ratio (numerically) at the wheels and therefore decrease acceleration slightly. The reverse holds true for a slightly smaller tire. With the sizes mentioned I doubt you would notice the difference.
Old 03-13-09 | 08:36 PM
Isfast's Avatar
Isfast
Thanks guys....how about the front tires?
Old 03-16-09 | 07:49 AM
DRE1615's Avatar
DRE1615
Bump...anyone have any further info on this. I'm also looking to possibly switch to different tires soon.
Old 03-16-09 | 10:38 AM
caymandive's Avatar
caymandive
11 Second Club
My next set of tires will be 265/35/19 for the rear. 255 is just not wide enough for the power. The 225's up front are fine though.
ItsanF
IS F (2008-2014)
18
09-30-11 06:52 AM
cleethree
02-28-11 08:14 AM
hybridanim
12-21-09 02:41 PM
sincityIS
08-24-07 10:06 AM
Gs L-tune
Wheels, Tires & Brakes Forum
14
09-06-05 03:26 AM
