DIY: IS-F front brake pads
#136
Tech Info Resource
You can reuse them. Get some of the Brembo goop though, it's copper based and definitely the premium stuff. Unless you have a jar of copper based anti-seize compound, then you're golden. (no pun intended)
#137
I've had my Carbotechs on since summer of 2010. Recently, I've been getting loud popping sounds when I hit the brakes. I'm going to pull the pads and see if I can find anything that stands out. I wanted to see if anyone else experienced this?
#139
Is Copper Anti-Seize the same? I've seen conflicting answers for this. Thanks.
#141
Carbotechs, up front only, have been working spectacularly well for me.
#142
#143
Tech Info Resource
When applying the disc brake grease, use the grease enclosed with a front disc brake pad kit or supplied grease (Part No. 90998-94072) or equivalent.
Copper based anti-seize is an equivalent.
#144
OK, this is and old thread but I have to post this. Thank you very much caymandive, I just did my brake pads install using this thread as a guideline and it went so smooth. I must just thank you again for the DIY and pics, this is the reason why I love forums. Just saved my *** a bunch of $$$ doing it myself. Also I installed the Project Mu pads and I must say I'm in love with them already. Doing a break in with the 60-0 stops like 15 times and driving for like 30 mins around town with stop and go, there is literally like a flew flakes of dust only! I'm in love. The bit is as good as stock but as others have said is not as grabby as stock. Project Mu for LIFE!
#145
is ne one else or is just me that my brake peddle feels a little mushy after i changed the pads..??
fyi...diy on the rear is so easy i just did mine all i had to do was just take out the two pins and the pads slipped right out after pulling them back enough so the new pads would fit in..
#146
no dealer in the bay area sells brembo grease. They only use the Toyota grease that is not copper based.
Is there a online site from a dealership that i could buy the brembo stuff? My dealers are all ghetto, doesn't even sell brembo grease. Apparently used just regular Toyota grease that is also used on Camry WTF!
#147
i just called my dealer again and they only have Toyota branded grease which they use to do on ISF all the time. It is freaking $42 for grease!, it is a large amount but who needs this kind of amount! Is there anything else you guys can suggest to get at a local parts store? Cause I just used some cheap old any grease from auto zone and now my brakes are squealing like crazy when using light pressure. I have to redo my brakes again!! ahhh I want to make sure I use the right stuff, don't want to do this a 3rd time.
#148
Tech Info Resource
#149
Just orderd a set of Hawk Ceramics and a set of Centric Cryo rotors (well orderd on 7/7 and just got the email they are shipping out the rotors today) for the front.
I have read good things about the Hawk pads and seams other brands are kind of skeptical compared to the OEM pad. Plus there is very little rotor options for us; they are one of the few companies that also offer the rear rotor that's why I'm going to try out the fronts.
I got a great deal thanks to my rep for the parts so if they suck then I will not feel to bad. I will be installing them myself thanks to the great DIY write up....I cant thank you enough, great job.
#150
lobux...
can you please clear something up for me
is this the brembo stuff? Part No. 90998-94072
or the toyota stuff?
I called lexus and the listing that comes up for that part number says just grease and he couldn't tell me which
