Is jdm inner panel box
Old 03-24-09, 12:18 AM
SmokeyMav
SmokeyMav's Avatar
Default Is jdm inner panel box
Hi, I was wondering if anybody installed the JDM accessories such as the Inner Panel Box. http://www.l-tunedparts.com/product/?id=2168
I just purchased the item but I'm having problems understanding how to install it. If anybody has this item installed in their IS OR IS-F please share your story. Thank You.
Old 03-24-09, 01:05 AM
ISCjonny
ISCjonny's Avatar
its a replacement for you ashtray and cigg lighter.. so that peice needs to be removed to fit the new inpanel box u ordered.
Old 03-24-09, 07:24 AM
clubfoot
clubfoot's Avatar
Once you remove the two silver trim pieces on either side of the center console the rest can be unbolted/unscrewed. Slide a credit card between the trim pieces and the outer edge of the center console, twisting the card as you go along and the trim will pop up and back a bit,...it uses friction clips.
Remember you will loose the cig lighter power port and will have to use the one in the armrest.
Old 03-24-09, 10:33 AM
blk250
blk250's Avatar
nice ....
Old 03-24-09, 10:34 AM
flipside909
Lexus Connoisseur
flipside909's Avatar
For that particular panel, I believe you would have to remove the center trim panel to access that section.
Old 03-24-09, 11:00 AM
flipside909
Lexus Connoisseur
Also you will lose the functionality of your dc outlet/cigarette lighter.
Old 03-24-09, 11:01 AM
Joe Z
Joe Z's Avatar
Received 1,063 Likes on 586 Posts
Lightbulb
^ Correct
Remove Shift ****
Remove Two silver Trim pieces
Remove small trim piece under radio
Remove entire center console panel.
then..
Remove two screws that hold ashtray box in place.
Unplug connectors for cig lighter & light.
Then just slide it up and outward.
Your going to have to transfer your Silver CF trim to the new box.
Very easy, as it just unclips.
Reverse procedure.
Joe Z
Old 03-24-09, 11:40 AM
rominl
exclusive matchup
rominl's Avatar
you don't have to remove the small trim piece under radio. as long as you keep the ash tray door closed you won't scratch anything.
Old 03-24-09, 12:01 PM
Joe Z
Joe Z's Avatar
Lightbulb
Argh.. you know me to well...
I now take precautionary measures and pull that little sucker out whenever I work on a unit..
Old 03-24-09, 12:12 PM
javyLSU
2IS OG
javyLSU's Avatar
^I would even say removing that piece increases the risk scratching the ash tray door...
Javier
Old 03-24-09, 12:14 PM
Low Offset
Low Offset's Avatar
why don't you use the sun glass holder on the roof panel? I find replacing the cig lighter a huge deal with just a simple storage box. And the price of $216? that's ridiculous.
Old 03-24-09, 12:16 PM
Joe Z
Joe Z's Avatar
Javier
Not when done right... but whatever...
Don't mess with me Javy!!
Old 03-24-09, 12:20 PM
javyLSU
2IS OG
javyLSU's Avatar
Well, if "done right" you wouldn't scratch anything, right? I knew that would get to you...
Javier
Old 03-24-09, 12:25 PM
Joe Z
Joe Z's Avatar
Lightbulb
Javier
Well, now you know why I remove it..
Its removable for a reason.. So it can be "done right"... Roflamo!!
Old 03-24-09, 02:30 PM
rominl
exclusive matchup
rominl's Avatar
yup, totally remember we all love you joe
Quick Reply: Is jdm inner panel box
