Help, Just Dropped it On Tein's
** Pictures to be posted tomm, It got dark outside fast !
This question is for everyone who dropped there IS-F.
I just lowered mine on Tein High Tech and tonight while driving home for the first time, I see that my headlights are aimed very high![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
Now what? has anyone else had this problem, if so whats the fix
Please help asap
Thanks
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Please help asap
Thanks
maybe the auto-leveling computer is getting closed to the limit since car is not dropped evenly front and rear. if that's the case, all you need to do is just the auto-leveling sensor that's right by the wheel. if it's like other lexus, you should just need to adjust the one in the driver rear
Lexus Connoisseur
Lexus Connoisseur
Should be on the left side inside of the rear wheel well.
Tech Info Resource
this happened when i lowered my 350 u just have 2 adjust the sensor in the back drivers side to factory spec looks like a bone.....when i did my is-f i looked at it and made sure 2 put it back the way it was and no light turned on....
I went under there, it looks a little different, but their was a line on the metal, so I adjusted it flush with the line, ill check tonight, to make the change effective to i have to shut the car on and off?
