20 Inch Wheels on an IS-F???
Old 03-27-09, 06:36 AM
2008IS-F
2008IS-F's Avatar
Default 20 Inch Wheels on an IS-F???
New to the forum and next Friday will be picking up my new IS-F once it arrives at the dealer. Apologies if this has been posted before but what is the correct wheel and tire setup if I am going to put 20 inch rims on my car?
Old 03-27-09, 06:49 AM
Cabinetman
Cabinetman's Avatar
Just curious why you want 20s? The stock 19s aren't bad and with a performance car you usually try to reduce unsprung weight instead of add it.
I'm not knocking you if it just an appearance thing. It helps with recommendations if we know what you want out of your new wheel/tire setup.
Old 03-27-09, 06:59 AM
2008IS-F
2008IS-F's Avatar
It is primarily an appearance thing, that being said I will be researching the 20 inch wheels to make sure I am not adding much unsprung weight to the vehicle.
There are a bunch of 20 inch wheels out there in the 20-24 lbs range.
Old 03-28-09, 11:11 AM
ISF FAN
ISF FAN's Avatar
Just remember that if you go with anything polished, you will see all of the brake dust...and there is a lot of brake dust!
yishin
IS F (2008-2014)
23
08-20-24 03:25 PM
eddyisf
Wheels and Tires Classifieds
11-19-14 06:59 PM
MYISF
IS F (2008-2014)
32
03-24-14 10:20 PM
MWhit02
IS F (2008-2014)
13
08-07-12 07:55 PM
Quick Reply: 20 Inch Wheels on an IS-F???
