Independent DYNO Proven results by "Caymandive" - no BS here!!
#136
They have a modular system like that for 350z and G35's. But if you just weld a fake shell on the outside of the exhaust so it just looks like it has a cat it shouldn't be an issue and you won't have to cut up the exhaust since the exhaust will run as is through the shell. You'll get the same sound, performance, not have to do any cutting and still pass the visual. After hearing how sexy the headers and exhaust sound I don't think I could live with the quiet sound.
One positive note though we'll finally be able to answer the "header only" question people have been asking. I also wonder how much if any it will affect the dip in the curve.
http://www.rpmoutlet.com/powercat.htm has some nice mini cats that should fit. I think it would be great to have these installed via V-bands with test pipes to interchange with. or just maybe there may not be any difference in power with the mini cats installed compared to test pipes. Guess that could be another dyno test later on. :P
![](http://www.rpmoutlet.com/images/mag14076.gif)
#137
Tech Info Resource
Might also want to talk to these guys:
http://www.randomtechnology.com/products.html
They've been doing high flow cats for a long time, and back in the day had a fully emissions legal Fox body Mustang running 10's.
#138
#139
Whats funny is the car with full exhaust (no cats) passes emissions just fine. All they do is read the OBD2 port. Unfortunately I found out the hard way is that in VA they do the "visual" inspection as part of the yearly safety inspection. So as long as you go some place that does not know this car comes with 4 cats from the factory then having just 2 cats passes no problem.
I had the Random tech converters on my Z28. Two on my 3 inch Y-pipe. It was still very loud, just not as loud as without them.
#141
Its progressively getting worse, especially with the roaming sniffer guys. Back in the day, we would just go rent a PO Box in a county that didnt require smog tests and register the car there. Damn state figured that one out and shut the loophole
#142
Tech Info Resource
At least Georgia is performance based. Unfortunately, OBDII cars have to have a working OBDII system, so no aftermarket engine management on a '96 or later vehicle. They also do look for something resembling a cat...
#143
Here is a little more info regarding the roaming checks:
http://www.deq.state.va.us/mobile/orefaq.html
So, in Northern VA, if you see an unmarked white van with a lot of cones and camera looking devices pointing at the road, thats them. I know one location they are at regularly, and I've seen them at once somewhere else. They usually set up on a slight uphill grade road with low speed limits so you cant just throw it in neutral and coast by. I figured that out with my Z28
#144
Well this is interesting!
So the headers alone will make more power on the IS-F than with a catback exhaust and stock headers. So for those of you out there with families, just not into the whole elevated noise level that come with aftermarket exhausts and willing to spare a few ponies, it looks like the headers alone are a great option. As pleased as I am with the results today, the PTS JoeZ exhaust is going back on the car in the very near future. I miss the sound and will need the additional power this fall if I plan to squeak into the 11's.
Stock exhaust with SIKKY Headers
http://www.youtube.com/watch?v=hFDU6pc7ziE
PTS JoeZ exhaust with SIKKY Headers
http://www.youtube.com/watch?v=BfrMU...eature=related
![](http://i123.photobucket.com/albums/o304/caymandiver75/Headers/stockexhaustwithSIKKYheaderscomparison.jpg)
#150
There is a dyno day next Saturday and have been asked to attend by local guy with a stock IS-F. Apparently there is a 2011 Mustang GT that will be on the dyno as well, so it should be interesting. I'd like to at the end of the event overlay the results from the 2011 GT, the stock IS-F and my car.
Aside from the exciting comparo that will occur this day with the battle of the 8's, I have also ordered the AFE dry filter to see if it's worth a few ponies. Stay tuned.
