TSW Indy 500's No Worky On IS-F!!!
Old 04-14-09, 01:59 PM
TinCan
TinCan's Avatar
Default TSW Indy 500's No Worky On IS-F!!!
I had TSW Indy 500's 19x9.5 w/40 offset tires 285 nittos on the 350. I just got an F and the tsw rear rims, hit the brakes. Should I use a spacer? I did try an 1/8th inch and still hitting the brakes. Could use a little help, thanks.
Old 04-14-09, 02:32 PM
CrazyMPG
Phat Monkey
CrazyMPG's Avatar
where is it hitting on the brakes? maybe a thicker spacer?...or just sell the rims and get new ones for the F!!! better offsets...you should get for the front if it is 19x9 +33-35 offset and for the rear 19x10 +35 offset!!!
Old 04-14-09, 02:47 PM
TinCan
TinCan's Avatar
Fronts are perfect!! I did a bit measuring looks like a 5mm spacer is going to work in the rear (fingers crossed). I forgot to measure the hub for fitment, I found a spacer that acts as both a 5mm spacer and hub centric ring.
Old 04-14-09, 03:52 PM
MRxSLAYx
MRxSLAYx's Avatar
Are these the recomended offsets? Anyone know what type of offset the guys with Volks have?
Old 04-14-09, 05:56 PM
primecut
primecut's Avatar
I wouldn't recommend using spacers on a performance car.
QFT! The stock BBS is much higher quality and looks wayyyy better than those TSWs! Unless you are using them for winter wheels.. but it's not winter.
Old 04-14-09, 06:42 PM
montgb
montgb's Avatar
My thoughts exactly. TSW is a downgrade for sure.
Old 04-14-09, 08:57 PM
CrazyMPG
Phat Monkey
CrazyMPG's Avatar
those should be the recommended offsets since I run those offset on my F...and I have volks and I am dropped on JIC Coilovers...lol
Old 04-15-09, 01:13 AM
IceIridium
IceIridium's Avatar
TSW's on an IS-F????
Old 04-16-09, 01:47 PM
TinCan
TinCan's Avatar
I put them on for fun... and yes they rub. I'll be swapping them tonight. Anyway, I want something that looks like this...
Old 04-16-09, 01:49 PM
TinCan
TinCan's Avatar
any brands to look for that aren't crazy high?
Old 04-16-09, 02:44 PM
TinCan
TinCan's Avatar
I found the 5 axis, s5:f wheel I may head that route
Old 04-16-09, 03:18 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Now thats a nice wheel!!!
Old 04-17-09, 04:45 AM
montgb
montgb's Avatar
Club Lexus Approved.
Old 04-17-09, 06:12 AM
Low Offset
Low Offset's Avatar
Hey are you cannysage from my350z? He had the same avatar.
Old 04-17-09, 07:49 AM
TinCan
TinCan's Avatar
nope... I'm TinCan from GTO, Scion and FJ cruiser forums.
Quick Reply: TSW Indy 500's No Worky On IS-F!!!
