Rear Deck RATTLE!!! :( Help Needed....
11 Second Club
I was hoping I wouldn't have to post in this thread as my car had zero rattles until I installed exhaust. Now especially when the car is cold I hear a rattle/buzz sound from somewhere in the trunk/upper passenger side deck. I'm 99% sure there is nothing touching the exhaust, but it's the exhaust tone that is causing something back there to make the noise. Anyone else have/had this issue and what did you do to fix it?
Oh, and I have not solved my rear deck rattle yet either....
11 Second Club
Weird that you have the rattle in the trunk now since your exhaust install. I feel like something is buzzing in my glove compartment/or side passenger area since the install. I'm going to have to remove everything in there and see if it still continues.
11 Second Club
Rear rattle fixed
Upon close inspection yesterday I discovered the source of the rattle/vibration from the back of the car. The muffler hanger was slightly off causing the rubber piece to compress and not allowing any clearance. I adjusted the exhaust at the flange as best as I could and ended up being able to add some separation by a few millimeters. For a temporary fix to ensure there would be NO contact, I took some rubber pieces and squeezed it into the rubber hanger which filled it out and gave me quite a bit more clearance so the noise is now gone. One of these days I'll get into an exhaust shop and have them tweak the metal exhaust hanger.
So now I'm pretty much rattle free aside from some rear passenger door panel/window area that is sensitive to the deep low pitch of the exhaust tone on slow accelerations in the lower rpms.
I have noticed a rattle noise from the rear deck but it only occurs when I am on bad pavement. On smooth pavement it is silent. It is not the speaker but I suspect the 3rd brake light or something up against the glass. I usually just turn my music up and it drowns out the rattle but I still want it gone. I know this thread is 11 years old but wanted to revive it to see if anyone else has experienced this issue and had a resolution.
