Rear Deck RATTLE!!! :( Help Needed....
This has been the one thing that has been absolutely driving me crazy. I know many of you including myself have experienced the rear view mirror shake(which YES I can live with), but have any of you had the rattle/buzz from the rear deck while playing your music loud?
I was at a local dealer having something else checked out and mentioned this to the tech when I was leaving. He told me to make an appointment come back and he'll take a closer look at it. Also said it's probably a minor fix "something that could be solved with some felt." Felt? Does that make any sense to you guys? Seems like the ghetto way to me.
After hearing this I tried to solve the problem myself, went in the backseat and checked if anything looked loose...but it didn't. I did take my jacket and stuffed it between the glass and the rear deck and POOF all of a sudden the rattle was gone. I'm not gonna drive around with a jacket back there, so once it's pulled out the rattles back of course.
Let me know if any of you have experienced this. Help me out...any suggestions? Any of you bring back to the dealer because of this and have them fix it with specific instructions? Thanks in advance CL.
Lexus Connoisseur
I had the same issue with mine. Try checking from the trunk, tapping on the upper trim right under the rear deck. I believe it's the rear trunk courtesy light which is tapping the metal making noise. If it makes that noise, point it out to your next service visit.
My setup rattled like no other until the dynamat. Afterwords it is sooooo much better. Main parts that rattled were the third brake light and the rear view. After the were quieted the moonroof started to rattle. ( The piece that pops up after you slide the moonroof back.) I will get to this either this weekend or next weekend and then let everyone know how it went.
Check the brake light and just put a piece of dynamat on it. One on top and two little pieces on the bottom and that will help 95% of it.
Most of the top of the rear deck, the rear doors, the trunk lid, side of trunk, 3rd brake light, rear view mirror and not sure where the rest is. (couple others spots.) Car does feel a little heavier and would not recommend to everyone but damn then rattles.
By the way Exclusiv.. Your car looks yummy.. What are you using for the drop?
Thanks and have a great weekend fellas.
No rattles from the rear, however lots of rattle from dash area. Lexus finally fixed, said that a fastener broke in the dash and this was causing the rattle. Since then, perfect.
Haven't found many that have. I have just added a 12" sub and amp and removed the factory woofer.
Still haven't got around to speakers yet but still sounds 10000000x better then stock.
Update:
So I thought it might be the plastic from the rear brake light rattling against the rear windshield's glass...but that isn't the issue. Sounds now like it is my entire rear deck rattling because when I press down on it there is no longer a problem.
Is dynomat my only option? Or will the dealer fix it this? Or Should I have faith that they even know how to fix something like this?!
Update:
On a side note, I went to hear the JoeZ exhaust after you and fell in love with it. Now I want to make the car even louder via radio and exhaust.
The factory sub served no purpose after the aftermarket sub was installed. When removed.. it actually turns into a big port into the cabin.
I have a single 12" FI- Q subwoofer, powered by a US AMPS MD 2D.
