BC Racing Coilovers
#33
I did the initial spec on spring rates and testing for these and still running them after 8K miles or so. I am still waiting on the rubber mounts for comparison to the pillow ball mounts. Looks like I may need to become a vendor here after all so that my hard work (and investment) does not go unrewarded. The product is good and my drop rates are 1" front and 5/8" rear out of the box but of course this is adjustable. Its a pretty perfect ride height IMO. There are a few times I forget how low I am and I have hit the nose on a few entries, but it is very drivable. These improve the ride drastically over OEM as the valving and stiffer spring rate reduce/eliminate the jarring effects of the stock shock valving. Handling is great and the adjustment offers a good range of usable settings. Softer settings are noticeable and the one thing that may be tricky is that fact that the rear trunk would need to be cut for access to the adjustment *****. I am working on something for that as well.
My pics on my OZ 19's.
![](http://i88.photobucket.com/albums/k195/Figbline720/isf/bcdrop1.jpg)
![](http://i88.photobucket.com/albums/k195/Figbline720/isf/bcdrop2.jpg)
Fig
Soon to be site vendor.
Fig
#38
These are made in Taiwan, which is not even close to the same as China. My impression of the materials and process is top notch.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
#40
The grill is something I am working on
__________________
