BC Racing Coilovers
#76
Thanks to all the experts here for their advice! I have 12k (front) and 10k (rear) and the sponsor I bought it from (Acute Performance) is nowhere to be found, shoulda known...
I'm going to give BCR a call today as I would definitely like to get 16k front or even 20k up front and 14k in rear as my springs are too soft for sure! grrr
I wonder how this swap would occur since no matter what there's labor involved plus my car would be stuck on the lift. I might just ditch these and get KW's.
Anyone know what KW spring rates are for the front and rear?
So where's the best place to buy KW's and cost?
rick
rick
#77
It's hard to relate spring rates from different companies, as some companies take a different approach altogether on rates and valving.
Burke has the KW's now and they have a much lighter rate than the BCR, but he said he still likes them a lot. The valving approach is completely different on the KW's.
We stand by what we sell and we are always here to answer our customers questions, on ANYTHING we sell.
S4 - If you have any questions on the KW's feel free to PM us, as we carry those as well.
#78
rick
rick
Gonna send you a PM with a quote I received.
#79
#81
rick
rick
11k front and 8k rear..
#82
in that case give me a new set of the correct ones that i want 16k/12k rear. this is what i want and i should not have to call bc since i bought them from u. and yes i was in a rush to get them but if i had been given an option i would have choosen these because its my track car. what do u say to that? help me circuit!!!!!!! since i did buy from u!!!!!!!!
We are here to help in any way we can, but we can only do so much.
Like I said, in order to get springrates like a 16k/12k setup you need a whole new set of revalved shocks, and then the springs.
We DO NOT get a discount on the revalved stuff, that all goes directly through BCR, not us. We DO NOT sell revalved shocks individually, it's a policy set by BCR themselves.
#83
what is the major complaint. what is everyone trying to do with these. I had no issues. i heard you can order spring rates and dampening levels and took advantage of it. reason for selling mine was only that i wanted dbl adjustable suspension and soon might go 3 way adjustable. the recommended rates are fine but stepping it up will kill the ride but improve the steer. the fit and finish as well as the settings are awesome. As for Circuit motorsports they handled my custom issue with NO FLAWS. Having what you want done and knowing how suspension works helps. I think CMS did an excellent job.
#84
I have PM'ed you multiple times in an effort to work something out. You had a special case on your set and we did what you requested of us at the time.
This is totally true... You be better off purchasing a new set of BC's then selling the old set.
Oh well... sometimes you have to learn the hard way, but I'm sure once someone gets their sweet spot on the setting they will love it.
#88
The Maker
One other work around you guys with softer springs can do is to preload the springs more. Since the BC's offer ride height adjustment and a spring preload adjustment independant of each other, I would suggest you compress the springs more and offset the ride height accordingly. This will at least give you a stiffer initial compression and perhaps better feel. The rebound may be more assymetrical with the single valve adjustment, but you may prefer the damping charateristics that way. Just a suggestion.
These are not necessarily straight forward things to decide when choosing a coilover. Its a multi-dimensional system and things could be drastically different when you actually start cycling things. Vendor to Vendor there will be valving curves, spring rate curves and finally fluid viscosity curves that vary with temp and seal wear. To put all of these things into a simplified solution is a problem. SO with that said I think that some of you may be able to get some different ride characteristics is you play with things a little bit.
Remember going stiffer can overshoot your goals and you could be left with a solution that nets you no additional traction, just stiffness and a rougher ride. For the track guys, it will also depend on what tire compound you run as R compound tires will let you push a lot more energy into the compression stroke that street tires will. With every variable change there is a compensation somewhere else...which is why championships do not come cheap at any level.
Fig
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#90
Have you ever tried the other coilovers for IS F?
I'm using tein h tech now
And i don't like it because the ride is too bumpy
I'm considering to buy the BCR coilovers but still i'm still confusing
Because some people like and the others don't
Thanks
Thanks
