BC Racing Coilovers
#121
Just got a baseline for corner balancing. My LF and RR is 50.8 and my RF and LR is 49.2 and that's with me actually sitting in the car. Now, I haven't done anything besides bolt on my BR Racing coilovers and they seemed to have been preset from Figs. I might just leave things well alone as it is.
Without me in the car, the 50.5 and 49.5 so obviously sitting in my car makes it less balanced.
The front/rear balance is quite off - but I have no spare and low fuel (drag racing mode).
And JUST in case you wanted to know, my drag racing weight is exactly 3700 pounds (that's with ME in the car). Empty weight for my car with low fuel is 3523 pounds.
#122
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#124
4 scales, one at each tire.
__________________
#126
It appears that the fronts are already at max height so I suppose I should preload just a little the back left side that will put more weight on the back left front right and maybe be closer to 50/50. Having said that, am I really going to notice a 1% imbalance?
#128
That is what we are here for, to specifically advise on setup which includes spring rate spec. There is more to suspension then just a spring and coil setup...next is the alignment.
__________________
#129
The 1% imbalance is not going to throw you off at this point, I would focus on driving now and seeing which damping settings will optimize handling with your driving style and preferences..
With camber and toe, I'm more interested in seeing how the tires were on day to day driving rather than track driving since that is what I do 99% of the time and I'd rather have even tire wear.
I'll adjust the front/rear bias through ride height, dampening, tire size, and possibly the anti-roll bars.
I haven't pushed my car because I have snow tires up front and Mickey Thompsons in the rear. But since the front is 1 inch and rear is .6 inch lower, I'm assuming we inscreased slightly the oversteer. Once I get my summer tires on, I'll verify that. If it's still too much, I might go to 245s up front and keep the 255 in the rear. I honestly think that's all I'm going to need to do for now - I'd rather have a slightly understeering car on a day to day basis.
The dampening is a little tricky for me. I tried 20 and 25 clicks and it felt with the springs, it was a bit bouncy and needed a more dampening. I'm actually back down to 8 and 10 and it feels really nice. I just like the handling and I actually prefer the flatter turning, more damped feeling - but at the same time, it doesn't feel more harsh than 2008 stock IS-F. I don't know why.
#131
Corner balance is NOT the height at each corner. It's is the weight at each corner. Imagine a chair with four legs. Imagine it teeter tottering. Corner balancing is like putting shims on the shorter legs so they don't rock anymore. So, front right + rear left = front left + rear right. You can't do it by height. You can google it - there are some good articles on it. Essentially a balanced car will turn right and left equally well.
#133
Another great thread found via search!
Thanks to all here for the copious and very helpful information. It convinced me to pick up a near-new set of these with 16/12 springs for track duty... Though I think the seller had them adjusted with quite a bit more drop than the 1.0F/0.6R I've read about so many times, which I think would be a good starting place for me with my aggressive 19x9.5 wheels and 275 square rubber.
Does anyone have a picture of how they're adjusted when new for said modest drop? I'd love to recreate this before slapping them on the car so I'm fairly dialed in from the get-go.
Thanks again!
Thanks again!
#134
Lots of well-respected posters with good on and off track experience here... Anybody?
Also, it looks like one set of Swift springs I ended up with are 7" length, and the other set 8"... apparently Swift has a some conflicting fitment databases. Will this be a problem, or is there enough adjustability in the height/preload adjustments to make up for it?
#135
