8.1 Nav/gps update for IS-F need help.
I just bought the 8.1 nav update and wasn't sure how to install it. I've searched for a DIY but no luck....anyone updated their nav? just curious to see if it even works? because our cars aren't listed, but i'm presuming its the same as the ISx50. All the info i gather is that, you have to take the clock out and remove the old disc, but I'm hoping someone would have pictures on how to remove them.
Lexus / Toyota / Scion Navigation DVD Generation 5 version 8.1
Toyota/Lexus GPS Navigation DVD for Generation 5
Map Data Version: 8.1
Part # PT219-GEN05-08
SKU: 86271-53023 464210-1160
Coverage: North America
GS350 2007 - 2009
GS430/460 2007 - 2009
GS450H 2007 - 2009
GX470 2007 - 2009
ES350 2007 - 2009
RX400H 2007 - 2008
RX350 2007 - 2009
IS250 2006 - 2009
IS350 2006 - 2009
GS350 2007 - 2009
GS450H 2007 - 2009
GX470 2007 - 2009
ES350 2007 - 2009
RX400H 2007 - 2008
RX350 2007 - 2009
IS250 2006 - 2009
IS350 2006 - 2009
i know its in the owners manual of the car. it states to remove plastic cover for the digital clock/surround for hazard lights. there is a small hole on either side of the piece. just remove the piece and behind that should sit the dvd slot. i know someone that has experience might be able to give you more specific details.
I bought it off ebay.......my dealers about 150 miles away from where i am at so.....i'm hoping that i can do this without taking a road trip.
can you ellaborate what page it is on, because I can't find any info on it at all on both Nav./owner's manual....or are you just assuming that its is on there? Maybe i'm just looking on the wrong section?
I did go through the books and nothing....so thats why i'm posting this thread up.
its in the navigation manual. the process starts on page 305 in the appendix section. good luck.
Search is your friend.
https://www.clublexus.com/forums/2307058-post66.html
BTW, don't use the Hazard switch as pull point to take out the clock assembly. The manual instructs to use a screw driver to pull out the clock by pulling the hazard switch. This did not work and scratched the hell out of the hazard switch (i had to buy a new switch 50cents from Trademotion and replaced it).
The best way to pull out the clock unit is by a small (less than 1" diameter) suction cups. It worked like a magic. After two pins in the holes are fully inserted, stick a suction cup on the corner or over the "Passenger" text on the clock assembly and pull it. On side should come out and do the same for other side.
Lexus should really include those suction cups as part of the tool. They really make you mess up the hazard switch by pulling it and that did not do jack squad to make it work
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
defo
07-08-13 11:55 AM
sfxr
01-03-13 10:27 AM
4642101160, 81, 8627153023, dvd, eject, hack, is350, manual, map, nav, navigation, pt219gen0508, pt219gen0509, sale, toyota
