Lexon Carbon Fog Lamp cover
Does anyone know if you have to take the front bumper off to take out the fog lamp covers? The CF wrap will be here later this week and I'm going to wrap them. Thanks in advance!
Tech Info Resource
According to Lexus, yes you do.
People on here have tried to resin the fabric (on interior pieces) without too much success. If you are gonna resin them why not just buy real carbon fiber matting? I think you'd have more success going that route.
Problem is, how do you get the carbon mat to stick to the plastic?
Tech Info Resource
not quite, they use a sprayed contact adhesive like an upholstery shop...non aerosol. The number one problem with resin on carbon is that the resin does not wick into the fiber. Then you get a MAGIC SHELL effect, then spider cracks...then rogue pieces flaking off. This my friends is why prepreg was invented.
Fig
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
Tech Info Resource
Fig
Fig
The manufacturers actually have to use this because it does not have VOCs. Super 77 does, so they had to stop using it.
Full catalog here.
