Lexon Carbon Fog Lamp cover
#34
This would make sense if the problem was the finish on the surface. It's not. The question is how to stick the fabric to the plastic.
3M 77 will work just like contact cement, and I've seen upholstery shops using it to stick fabric to plastic for years. If I were putting faux CF with a fabric backing on anything, I'd use 3M 77 because I know it will work and stay stuck for a long time.
A good uphostery shop will use something similar to this http://www.carcraft.com/techarticles.../photo_10.html
This is one type we used, much better than anything you can buy in a can.
http://www.keystononline.com/index.p...3=&productid=1
We had it in a 2 gal. paint pot and it worked great. There is also a more tacky type of contact adhesive which does not require the sides to dry. Either of these are much better than 77
or K-grip adhesive as it has a much higher holding temp (215 F). Have you seen how hot things can get in the sun?
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
#35
looks great. Looking at the surround that there are only 2 clips to hold it on. Is there a way to get to those 2 spots without removing the whole bumper? Looks like if you yank hard enough at those 2 spots it will pop off? Also since it looks good on the outside of the car what about wrapping the grill surround to match.
#44
lexus2114
01-20-19 08:04 PM
mdsbrain
11-19-10 10:48 AM
