What are those three buttons?
The three buttons just to the left of the steering column? I've missplaced my manual and cannot figure it out. Please help if you can.
mostly the TPMS the park assist and the laser cruise if equipped.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
Received 1,063 Likes
For an IS-F with optional Parking Sensors, it will allow you to turn them Off/On and rear distance sensor control..
(I'm not sure about the Radar Cruise Control feature)
That’s about it..
Joe Z
Lexus Connoisseur
The multi function keys only operate as JoeZ mentioned, the AFS, TPMS A/B selection, and TPMS reset...and Park Assist on/off for those with that option. This is what is displayed on the multi function display on the upper center of your speedo cluster.
![](http://www.flipside909.com/gallery/albums/093007ISF/IMG_0948.sized.jpg)
Radar Cruise is only operated via the radar cruise power button (which is on the steering wheel just below the Phone/bluetooth & Display, Talk command button on the right side of the wheel.) and the main cruise control switch stalk. This is a blank spot for most of us.
![](http://www.flipside909.com/gallery/albums/093007ISF/IMG_0995.sized.jpg)
Those buttons will allow you to change the setting on your TPMS, turn on and off the adaptive headlight system , and to turn on and off the park assist.
matchflick
02-10-24 12:42 PM
TFBTRADE
01-03-23 12:49 PM
