homelink question
Old 06-14-09, 09:39 PM
yummy
yummy's Avatar
Default homelink question
Hey guys i have a question about the homelink system . I was wondering if i happen to park my car outside my house. Then lets jut say if someone breaks the window will the homelink system still work to open my garage door and will be able to get into my house?
Old 06-14-09, 09:53 PM
malujerry
malujerry's Avatar
if they are smart enough to power up your car, then yes.
i leave my inside/house door in the garage locked just in case and i programmed the home button in my navigation to the local police station.
Old 06-14-09, 09:59 PM
rominl
exclusive matchup
rominl's Avatar
you sure? i believe on lexus the homelink will still work when it's shut off. i am not 100% about is-f, but considering that's the case on gs400, gs350, sc430, is300, and ls460l, i would be surprised if the is-f is designed differently?
Old 06-14-09, 10:12 PM
malujerry
malujerry's Avatar
damn it, you beat me before i came back from the garage!! i was like crap, i have to edit asap!!! (i just saw hangover and was bs'ing with my friends on the phone since my bachelor party in in a few weeks and responded without checking first )
so i stand corrected, even with the car off the home link does open the garage
Old 06-15-09, 06:41 AM
Civic Si-r
Civic Si-r's Avatar
Worst case scenario. Thieves break into car, your FOB is nearby, sure lets try to start the car with just 1 push of the button......it works!!!. They drive off with the car and steal your homelink code and transfer it to another hand held remote. Go back to your house, when your not home and open the garage and take everything
Old 06-15-09, 07:56 AM
IS-Fly168
IS-Fly168's Avatar
thats one thing I like more about a mercedes, they dont work without the key in the ignition.
Old 06-15-09, 09:00 AM
Evil Teo
Evil Teo's Avatar
park ur car in the garage that will eliminate them from gaining entry to ur car and garage. the fob has to be in the car to start the ignition. never leave the fob in the car.
Old 06-15-09, 10:56 AM
rominl
exclusive matchup
rominl's Avatar
yup, same with bmw, homelink doesn't work when car is off.
sometimes i wonder what's lexus intention in this too.
Old 07-13-09, 06:19 PM
djrobsd
djrobsd's Avatar
It seems to me, IF you could trace the wiring on your rear view mirror back to the fuse box, you could re-direct the wiring to a connection that is not always hot, but I'm not an expert in car wiring, this is just an idea, i wonder if anyone has tried this?
Old 07-13-09, 08:18 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,074 Likes on 2,469 Posts
Usually if they've applied power with the key off it's to retain the memory. Anybody had to reset their homelink after disconnecting the battery?
If it is just a wire swap, I'm pretty sure I can post a "how-to" shortly.
Old 07-13-09, 09:18 PM
rominl
exclusive matchup
rominl's Avatar
not 100% on is-f, but on my other 5 lexus, disconnecting battery doesn't kill the homelink memory
Old 07-13-09, 10:00 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
So there are three wires identified in the EWD for mirror. The pink wire on pin 5 gets its power from the Dome fuse, so it is unswitched. The black wire on pin 4 is switched power. Disconnecting the pink wire from the connector and splicing it into the black wire will provide switched power for the garage door opener.
I'm not particularly keen on trying this myself. My cars are never outside my house.
Removing the mirror requires a Torx T20 and removing the cover between the mirror and the upper center console.
Disconnecting the power will likely require you recalibrate your compass as well. Instructions are in the Owner's Manual.
rijc99
10-10-20 07:30 PM
jdm_altzza
IS F (2008-2014)
03-04-15 06:08 PM
vbx
10-12-13 08:17 PM
Defratos
IS F (2008-2014)
13
02-12-13 01:12 PM
Quick Reply: homelink question
