ISS Performance IS-F QES Street / Track Exhaust
#317
Here are 2 different cars both running their own base line Dyno Numbers.... There were other runs showing higher numbers and lower numbers under different stress levels. We noticed the Exhaust helps most when you build temperature into the equation. The motor was under less stress with the exhaust then with the stock system. We will post the numbers on the production system when we get the first one done. I would also like to see the number when it get a little cooler in Miami.
#321
The last one is in Smoothing 5. We did the first one in Smoothing 0 because it is the only way to make 333whp in 98 degree weather. The numbers in smoothing 5 decreased 2.7 WHP in both the base line and with the exhaust. We were more interested in gains then actual numbers. Numbers vary due to temperature, altitude, humidity and so on.
Thanks we feel the same way!
#322
How about a format, so that even if the image gets deleted it will be useful. like for instance:
Facility:
Type of Dyno:
Baseline # for a stocker at the dyno:
Boost:
Fuel:
Target AFR:
SAE Corrections:
Peak HP at RPM:
Peak Torque at RPM:
Mods:
#324
3M black molding tape should be here next week.
Grill is getting painted black gloss next week.
Rear roof spoiler going to paint and going on next week.
Going to leave front badge and rear badges chrome for now, will compliment exhaust tips and headlight housings.
She's still a work in progress, but I'm with you Rob on some of your suggestions,
thanks.
thanks.
#326
FNMUPN where are you getting your stuff done? I have the 3m tape also. I like to have my paint done by Touch of Class in southbeach great work (cheap) and highly recommended. Very well known even Janoy was like wow they get around.
#328
Not sure yet, but taking recommendations. I will check out the shop you mentioned. Need some bumper work too, got scraped up last week on rear bumper. Might just be a buff job but it looks pretty deep to me. When you getting your F back from the mad scientist and the evil genius aka Paul and Janoy? Those black tips came out nice! You going full track version still?
#329
Definitely,
You guys should try to make it to one of the upcoming PBIR events
https://www.clublexus.com/forums/flo...-sep-11-a.html
https://www.clublexus.com/forums/flo...his-again.html
