Engine Metal Clicking Sound..Help!!
Old 07-16-15, 06:07 PM
  #271
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,963 Likes on 2,400 Posts
I bet when they replaced the compressor they replace the serpentine belt too. When I changed mine, it went away for a while, but came back in a couple of months. Report back in a few months and let us know if the compressor swap was more permanent than my belt swap.
Old 07-17-15, 07:24 AM
  #272
H1_OFICR
H1_OFICR's Avatar
Default Engine Metal Clicking Sound..Help!!
Originally Posted by digger08
I just picked up my car this afternoon. So far the noise is no longer present after the AC compressor change.
It had been sitting at the dealer since Friday with out starting and they waited for me to arrive.
I am fairly convinced that this was the issue (in my situation). The engine actually sounds quieter than it ever has.......I will also check for the belt squeak at WOT. A wonky compressor pulley may also be responisible for the belt slap issue during hard acceleration...IMO
I will continue to monitor over the next few days on cold starts and report back.
Update: after some more mileage - the belt slap has comepletly disappeared, and all metal rattle noises have been eliminated. I also used to have a hunting idle issue that is now steady as a rock while in park.
I am really happy about this, as it has eliminated all of my concerns
Digger08
Lobuxracer
Since you have a pretty loud noise and are pretty mechanically inclined..(or anyone who has a loud persistent rattle) . Do you think it would be possible to put a smaller serpentine belt on so as to bypass your ac compressor. I would think this would definitively prove this theory either way. If not I may take my car to the dealer and attempt to get them to do it (my noise is very intermittent though)
Old 07-17-15, 10:57 AM
  #273
lobuxracer
Tech Info Resource
lobuxracer's Avatar
I doubt you'd be able to route the belt to bypass the A/C compressor. It's not a simple configuration at all.
Old 11-02-15, 12:16 AM
  #274
waloood
waloood's Avatar
Default could u plz PM me
Originally Posted by carlosg
FYI this was the work done to one of the members of CL
could u plz PM me.
coz this picture is not clear.
Old 03-16-16, 02:52 PM
  #275
NPSC303
NPSC303's Avatar
Any developments on this? My 2011 w/ 39k miles does the same thing....
Old 03-16-16, 07:35 PM
  #276
k20trick
k20trick's Avatar
The noise is normal dont stress about it.... at the dealer lot an 2013 with 30k miles had it and so does mine I dont even notice it anymore and it only happens sometimes. Like mentioned earlier in this thread, this is a common sound. Until someone posts a catastrophic engine failure post after hearing that noise, I'll keep enjoying my isf.
Old 03-16-16, 07:42 PM
  #277
I8ABMR
I8ABMR's Avatar
WOW! Thats is WAY louder than less consistent than mine. Mine is like a soft even tapping but its there. I absolutely noticed little to no ticking when I added a can of Octane booster. I am adding another can this weekend and I will see what it does or doesnt do in terms of noise
Old 03-16-16, 07:52 PM
  #278
lobuxracer
Tech Info Resource
lobuxracer's Avatar
I did some investigation last summer one morning and found removing the oil fill cap made the sound much louder. It isn't what I would expect from valves or rocker arms, but empirical evidence points to them.
Old 03-16-16, 09:13 PM
  #279
Joe Z
Joe Z's Avatar
Received 1,063 Likes on 586 Posts
Lightbulb
I did the oil cap test the other night... No volume change for me..
On a side note.. My noise always occurs with fresh oil.. And then goes away about 1-2k miles after change.. By the time I reach the 5-6k mile OCI.. There's no more noise.
Joe Z
Old 03-16-16, 09:22 PM
  #280
digger08
digger08's Avatar
Mine has never returned.
Digger08
Old 03-16-16, 09:25 PM
  #281
Joe Z
Joe Z's Avatar
Digger08
Since you....???
Old 03-16-16, 10:31 PM
  #282
I8ABMR
I8ABMR's Avatar
Digger08
Digger since we spoke I have been thinking of simply buying a new AC compressor and just ending it. A member on a Facebook page told me Delco makes the part for less than $700.
Old 03-17-16, 07:51 AM
  #283
digger08
digger08's Avatar
Originally Posted by Joe Z
Since you....???
quote in post 272
Digger08
Old 03-17-16, 09:18 AM
  #284
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Delco? It's a Denso compressor.
Old 03-17-16, 09:40 AM
  #285
mikersoft
mikersoft's Avatar
"Delco, Denso.. whatever it takes."
Quick Reply: Engine Metal Clicking Sound..Help!!
