Engine Metal Clicking Sound..Help!!
Old 06-27-09, 01:21 PM
  #61
Joe Z
Joe Z's Avatar
Received 1,063 Likes on 586 Posts
Lightbulb
Good info on your gas & oil usage.!
Originally Posted by Salil022
Ticking sound is normal due to direct injection...But the METAL CLICKING sound is not normal...That metal clicking sound can be heard by the wheel well.
Well I spent about 10 minutes with my engine this morning...
We all clearly have the Injector ticking sound, which is very prominent with the hood open and in the area next to the brake fluid reservoir. Normal.
I definitely do not have that "inconsistent" tapping sound that you guys are hearing near the driver side wheel area..
It almost sounds like its coming from the exhaust manifold or something...
What I would like for one of you to do is, try giving the gas pedal a few light revs while hearing that sound... It would be interesting to see if the sounds speeds up with the revs or if it stays the same or if it disappears..
Also, lets see what happens to that sound when you put a load on the engine.
Example: Switching from Park to Drive, but just sitting on the brake pedal.
Regards,
Joe Z
Old 06-27-09, 01:35 PM
  #62
Salil022
Salil022's Avatar
I'll record the sound for you this evening Joe...but metal clicking sound does not get louder when revving and sound gets a tick louder under load...I'll post it soon!!
Old 06-27-09, 01:49 PM
  #63
Joe Z
Joe Z's Avatar
Lightbulb
Thats exactly what I was looking for.....
Old 06-27-09, 03:37 PM
  #64
larrysb
larrysb's Avatar
If they all do it, then it is almost certainly normal.
High performance engines, which the IS-F's engine most certainly is, often are noisier and bumpier and rumblier than luxury car engines, even if they are based on the same basic design.
The ramp rates on cam lobes and the clickety-clack of high flow injectors, a bit of slap from short-skirt pistons and so on, are just part of the fun.
Old 06-27-09, 04:26 PM
  #65
FPR1939
FPR1939's Avatar
If Lexus won't do anything to it, I'd say just drive the heck out of it and if the engine crashes let them put a new one in it. That's why you have the warantee (I have the extended warantee up to 100k miles).
Pat R
Old 06-27-09, 04:45 PM
  #66
ngl1145
ngl1145's Avatar
My ticking under a rev gets slightly faster as I press on the pedal gradually. You can hear the inconsistant sound get faster then it sort of drowns out by actual engine sound.
Old 06-27-09, 09:37 PM
  #67
2LTurbo
2LTurbo's Avatar
i had a very similar sound coming from my 2004 S2000. Turned out to be the Timing Chain Tensioner (TCT). I bought a new one from the dealer for ~150 which solved the problem. Worth looking into...
(not my car)
http://www.youtube.com/watch?v=_ZVrJIkrp-Q
Old 06-28-09, 01:19 AM
  #68
Audriuss
Audriuss's Avatar
Always premium
maybe try to use several tanks of regular?
I use regular aka 95 (in Europe), and have no problem about it...
Maybe the sound comes from premium fuel using owners?
Old 06-28-09, 07:50 AM
  #69
Salil022
Salil022's Avatar
I think in a high Compression motor like IS-F only Premium gas should be used....As i have been using premium in my other cars as well and never had any problem
Old 06-28-09, 09:18 AM
  #70
Joe Z
Joe Z's Avatar
Lightbulb
I would say it wouldn't hurt to switch to a different brand of gas in the meantime...
Well we don't have many choices of Octane here in the US (per state)
Example:
In Cali, you mainly find 87, 89 & 91.
In NY, you mainly find 87, 89, & 93.
These are just the Basic/Avg Octane levels, different gasoline vendors can cary an extra higher grade where available.
I'm running Chevron 91 Oct, still with the JDM regular factory oil..
JoeZ
Old 06-28-09, 10:56 AM
  #71
flipside909
Lexus Connoisseur
flipside909's Avatar
Metal clicking sound and does not increase when revving? Could it be your belts or pulleys making the sound? Maybe the alternator?
Old 06-28-09, 11:41 AM
  #72
Salil022
Salil022's Avatar
Not sure if the metal clicking sound increases due to engine sound getting louder as revving and overcoming the metal clicking sound
Old 06-28-09, 10:04 PM
  #73
Salil022
Salil022's Avatar
Here is the video as joe z has requested:-
http://www.youtube.com/watch?v=GSe17VlF_QU
Old 06-28-09, 11:16 PM
  #74
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,971 Likes on 2,403 Posts
After that I'm inclined to agree with the cam chain tensioner fault. A loose valve continues to tick regardless of rpm. Your noise definitely goes away with a little rpm. There are four chains driving the cams, and four tensioners. One could be bad.
Old 06-28-09, 11:20 PM
  #75
Salil022
Salil022's Avatar
Will a bad tensioner cause the sound to be only noticeable once the engine is warmed up?
Quick Reply: Engine Metal Clicking Sound..Help!!
