Alignment settings for IS-F (Stock)?
I have done some searching but have not been able to find this posted. Does anyone have the stock alignment settings for the F?
Thanks!
Thanks!
Tech Info Resource
Specs are here.
![](https://www.clublexus.com/gallery/data/500/IS-F_Suspension_Specs.JPG)
FWIW, the angle measurements used by many of the alignment shops are assuming you are running OEM tires and wheels. If you are not, angle measurements for toe can be VERY wrong.
Tech Info Resource
Fixed. Forgot it's in a different section.
UCrazyKid
IS F (2008-2014)
26
03-10-20 09:44 PM
