homelink
Actually, I'm sure all Lexus's will open the garage door with a simple press of the home link button with or without the car being on. Try it.
In addition, it's wise not to program your house address as home on the nav, thieves can simply get back to your house from anywhere and open up the garage if it is all programmed in. I saved the police station as my home address for jokes.
The home link will only work if you enter the car with the key present. the car detects the key which will allow the garage opener to work. but if you enter the car with out the key the home link will not work. Ie. if your sleeping and some one breaks in to your car and tries to use the home link it will not work. now if your keys are stolen then your S#!T out of luck.
Lou
Tech Info Resource
I installed an autodimming mirror with homelink in the wife's Scion tC this week. Very simple install. I had to turn the ignition on for the programming to work and did not have to do anything with the three garage door openers to make them respond to the commands from the mirror.
As a test, I tried opening the doors with the key off and not present. All three doors opened with the engine off. There is a connection to B+ (battery), and a connection to IGN (switched power) from the mirror. This is the same with the IS mirrors. As I said before, I'm not particularly keen on finding out if I could bridge power from the IGN to the B+ connection and remove the B+ connection from the car side. I have no idea what it might upset in the $280 Scion mirror or the $808 Lexus mirror.
My cars are NEVER parked outside. That's why I insisted on a three car garage.
minlite
NX - 1st Gen (2015-2021)
08-31-16 04:19 PM
tresmith00
06-10-15 03:51 PM
