homelink
hey guys i am wondering how do you program the garage remote? i read the manual and followed the directions but it will not work.
i tried to program it at my old home, and it didnt work and now at my new house i moved to it still wont work.
i hold down the home link button and then hold down the garage remote button for like 30 seconds and nothing happens the homlink button just keeps flashing slowly. i tried this with the 1st,middle, and 3rd home link buttons with no avail. am i missing something?
You probably have one of the newer rolling code garage openers so you have to follow a different process. I've done this over a dozen times now and the manual is not clear so do this:
***First park your car inside the garage safely so it does not get in way of garage door since it will close when you do the programming. Park near the MAIN unit but be sure you can reach the "LEARN" button on the back of the main unit for step 3.
(button is most likely a red, blue or orange button depending on what frequency you have)
1) Hold buttons 1 and 3 down and wait 20 seconds till the LED starts to flash rapidly (this engages the learning mode and clears out all the old codes)
2) Hold the button you want to program and the LED will glow. Next press and hold your garage remote next to it until the LED goes from slow blink to fast blink which means it's learned the code BUT WAIT YOU ARE NOT DONE!
3) Quickly get out of car and press the LEARN button on main unit, next hop back into car and press the car button you just programmed once, then press again. This syncronizes the rolling code and if you do things right, you will see the garage light blink twice. Press it a third time and your garage will work!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Now you don't need the pesky remote anymore!!!
rick
rick
Now, I know this might sound dumb, but I knew how to program rolling codes, etc etc, and ran into the same problem as you and turns out for some reason I wasn't able to program it with the car turned off. =P So if you're doing it with the car off, it won't program.
In addition, it's wise not to program your house address as home on the nav, thieves can simply get back to your house from anywhere and open up the garage if it is all programmed in. I saved the police station as my home address for jokes.
^ Wow malujerry...I'm going to check when I get home - if that's true, stupid Lexus engineers! ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I know for a fact BMW does not operate without the key in ignition and that's how it should be IMO.
Funny idea for the police station addy - but if they are driving your car that means they have your keys so either way you are screwed....this is why for portable navi units they suggest you secure it with a unlock code. I don't think the Lexus OEM NAV has this feature for password unlock?
And no password for the built-in navi that I know of.
Tech Info Resource
Lexus is more worried about law suits than real security except when it comes to their intellectual property.
Tech Info Resource
They did kill the "I Agree" screen not too long after I complained on the Forum about nearly getting in an accident because I was distracted by hitting the "I Agree" button in my 350. Still there are many small details where their security model is compromised for convenience over security.
