Old 12-16-14, 01:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
Print Wikipost
The $200 IS-F Exhaust Mod
Old 01-13-15 | 04:07 PM
  #46
lifethinkr's Avatar
lifethinkr
Im ready to do this mod but I need to see some pics of the muffler section. the mufflers are huge. so a straight pipe goes in-place of the muffler? do you just weld the tail pipe with the duals to the straight pipe?
Old 01-13-15 | 05:35 PM
  #47
jt321's Avatar
jt321
You just cut off the secondary cats and weld in straight pipes and also cut off the muffler and weld in straight pipes.
You do not weld the dual tips to the straight pipe, there is going to be a space between the straight pipes and the dual tips, just like how there is a space between the muffler and the dual pipes now.
Ill try to take some pictures tonight and upload them so you can get a visual of what it looks like.
Old 01-13-15 | 06:47 PM
  #48
toyer14's Avatar
toyer14
Default excited
So this mod, wont effect smog tests and codes right cause its passed oxygen sensors? And pics would be nice to see just for install and what it should look like. Havent heard the sound though all videos are no longer available. I would like to hear what it sounds like before modding. Why delete the mufflers after the cats? And its a butt dyno increase of an actual dyno increase?Thanks for all the info and help.
Old 01-14-15 | 08:30 PM
  #49
lifethinkr's Avatar
lifethinkr
how's the drone at 2k RPM?
Old 01-15-15 | 08:25 AM
  #50
PatrickISF's Avatar
PatrickISF
There is some drone around that mark. I can't compare it to any other exhaust systems for the F since my car is the only one I've been in with an exhaust. I've gotten used to it.
Old 01-15-15 | 09:09 AM
  #51
lobuxracer's Avatar
lobuxracer
Tech Info Resource
Passing smog will depend on the state. If they just plug in an OBDII reader and look for codes, you'll likely pass. If they do any visual inspection, you will fail. Mufflers are required in all 50 states, so not having mufflers will definitely run a risk. I definitely would not drive in California with straight pipes. The CHP can (and I have seen) pull over any car they deem suspicious for violating smog laws. They will impound your car if it is not in compliance. This happened to a good friend of mine who was only guilty of driving a lowered car with legal tint. Think about how much you want to risk being hassled by the police before doing this mod.
Old 01-15-15 | 01:06 PM
  #52
VtotheJ's Avatar
VtotheJ
Old 01-21-15 | 04:08 AM
  #53
toyer14's Avatar
toyer14
bump,bump,bump
Old 01-21-15 | 07:50 AM
  #54
VtotheJ's Avatar
VtotheJ
Toyer i think those 3 videos should answer all your q's
Old 01-21-15 | 09:20 AM
  #55
calteg's Avatar
calteg
I had atrociously bad drone doing this mod, but I was straight piped all the way back (didn't keep the stock resonators). Sounded great at WOT, but the drone was so bad I went back to stock a few weeks later.
Old 01-21-15 | 05:01 PM
  #56
toyer14's Avatar
toyer14
is there any power gain with this mod?
Old 01-21-15 | 05:54 PM
  #57
lifethinkr's Avatar
lifethinkr
I would have at least tried to install the resonator before going back all stock. I want to do this, but I'm just frightened of the drone. maybe ill do some flow masters? with the secondary cat delete.
Old 01-22-15 | 06:09 AM
  #58
juanmedina's Avatar
juanmedina
Were can I get a header to catback flange? Or what is the size of the flange? A technical drawing would be awesome
Old 01-22-15 | 10:15 AM
  #59
PPEHeaders's Avatar
PPEHeaders
Sponsor
We have them. email me at sales@ppeengineering.com and I will look up a price for you.
Old 01-29-15 | 05:22 AM
  #60
juanmedina's Avatar
juanmedina
Thanks ^
So end up doing the mod; removed the cat and the mufflers. It sounds awesome, the car is quite if you keep the rpms really low. at 45mph, 60mph, 70mph the car is quiet almost like stock. Getting up to speed is a different story, there is a lot of drone at around 2000rpm but if you keep it below that or above that the car is surprisingly quite. At 80mph it kind of sucks since I am right at 2000rpm but when I drop a gear to get out of the 2000rpm zone the drone disappears and its hust a little bit louder than stock.
There is definitely and noticeable increase of power . Also the weight saving are decent, I weighted the muffler and they weight about 14.2lbs, I didn't have a chance to weight the cats. I believe there is about close to 40lbs in weight savings...
